Question about LG Dryers
My LG Tromm dryer is not drying clothes. When I turn it on and look at the back of the dryer I notice a glow coming from the inside but it turns off within 10 seconds. Could this be the ignitor or gas valve? If either one can I fix it myself or do I need to call a tech?
  • maxt12 Oct 16, 2010
    I can see the diagrams but the comments on the right are cut off. Can you copy and paste the text in an email so I can read all of them?
  • LG Master
  • 3,051 Answers
Hello there i will post this in 2 or 3 post to ensure i get it all to you
Gas burners can generally be divided into two broad categories; pilot and pilotless ignition. Pilot ignition models have not been manufactured in a number of years, and thus tend to be older units, but there are still a significant number of them in operation.
The main components of the system (see Figure G-2 and G-2a) are the gas valve, venturi and burner chamber, and gas safety solenoids (in all models,) the flame sensor and the ignitor (in pilotless models,) or the pilot orifice and sensor (in pilot models.)
IGNITORS
Posted on Oct 16, 2010
  • 6 more comments
  • Michael Thomas
    Michael Thomas Oct 16, 2010
    Figure G-2a: Late-Model Split Coils
  • Michael Thomas
    Figure G-2: Typical Gas Burner
  • Michael Thomas
    PROBLEMS
    COMMON TO ALL BRANDS 2.
    When the air in the dryer drum
    reaches the chosen temperature (as sensed by the thermostats) the gas valve
    will close and the flame will shut off.
    2-3(a) GAS BURNER SYMPTOMS
    AND REPAIR
    IGNITOR DOESN'T GLOW (PILOTLESS
    SYSTEMS ONLY)
    Nine times out of ten, if the
    ignitor is not glowing, it is burnt out. Unplug the dryer and remove the
    burner assembly as shown in figure G-4. Usually you will see a white or
    yellowish burned area and a break in the ignitor. If so, replace the ignitor.
    If you can't see an obvious break, test the ignitor for continuity as
    described in section 2-4(e).
    If the ignitor is not
    defective, you need to isolate whether the problem is in the control
    (thermostat) area, or at the burner itself.
    Figure G-3: Ignitors
  • Michael Thomas
    Figure G-4: Removing the Burner Assembly
  • Michael Thomas
    The general idea is that if you have 110 volts getting to the burner assembly, then the thermostats are OK, and something in the burner assembly is bad. If you don't have 110 volts at the burner, then a thermostat or some other control is bad.
    Perform the following test:
    1) Unplug the dryer and open the burner inspection cover as described in the chapter about your brand.
    2) Unplug the main wiring harness leading to the burner assembly. (Figure G-4)
    3) Using your alligator jumpers, connect a VOM to the dryer side of the harness plug. (as opposed to the side of the harness plug that's connected to the burner.)
    4) Make sure no wires will get caught up in the turning drum. Set your dryer timer to the "on" position, high heat, and plug in the dryer. If your VOM reads 110 volts, something in the burner assembly is bad. If the burner isn't getting voltage, the problem is in one of the components of the heating control system: a thermostat, timer or temperature control switch, or motor centrifugal switch.
    If you trace it to the burner assembly, and you've already eliminated the ignitor as the problem, either the flame sensor or the gas valve solenoid coil(s) are bad. Unplug the dryer, disconnect the flame sensor and test it for continuity. If you have no continuity, the flame sensor is bad. If you have continuity, the coils are bad. Bring the burner assembly to your parts dealer to make sure you get the right coil assembly, and don't forget to bring the model number of the machine.
  • Michael Thomas
    also can i get the model number i have a repair manual for you
  • Michael Thomas
    Yes just send me your e-maiil address and i will post it to you and the model number will help greatly
    Best regards MIke
  • Michael Thomas
    Hey there again hey can you send me a e-mail with your make & model number
    To tbirdfan1@yahoo.com
    I have a repair manual and some more things that will help
    Best regards mike
Clothes aren't getting dry
Check your vent hose and where it exits the building, clean away all lint anything blocking the vent cap or in the vent hose. Remove the vent from the back of the dryer and make sure it is all clean and clear there and make sure the betn is not kinked up when putting the dryer back into it space. Now before you blow me off, if any of this is true for your dryer the heat will build up and trip the thermostat causing it not to heat properly and the blower wheel can not move the air to collect the moisture and remove it from inside the dryer. Also, any sagging vent line can collect moisture which turns to a puddle of water in the line and this to will not allow your dryer to dry the clothes. Good luck I hope I have helped you.
Mar 30, 2014 | LG Tromm Electric Dryer
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 | Dryers
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
My LG TROMM DLE7177 on heating cycle finish much quicker
First off, unless you are using the manual dry (timed dry) option, the times listed are strickly an estimate. At the begining of a cycle, the dryer has no idea how big a load you have, how wet it is, and how good your vent is. In your situation, I would clean off the two silver colored moisture sensor bars, located just inside the drum, by the right side of the lint filter area. They are curved, about 5 inches long, and about an inch apart. If you use fabric softener sheets, they can aquire a waxy build up, which inhibits them from detecting that the clothes are still too wet.
Aug 27, 2009 | LG DLE7177 Dryer
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
LG Tromm dryer now takes two cycles to dry a load
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
Dec 20, 2007 | Dryers
Dryers Logo
141 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
