I bought a new LG 512M flash drive and since I got it, it has never worked If I slot it the Computer recognises its presence but could not store data on or retrieve data from it. Please what do I do?
  • 44 Answers
If it came with a cd use it first. If not format the unit first
Posted on Jun 03, 2008
Recently , you purchased a USB flash drive that you plan to use to store work-related files. When you attempt to store a file on the USB flash drive, the computer displays an error message indicating that...
You failed to mention what operating systems are involved. What does the work computer use as an operating system. The file system format of the USB may be say as an example ntfs windows while as a hypothetical the work computer could be apple o/s using a different file system or even maybe a unix system. You may need to reformat the usb stick to be the format file system used by the work computer. Also there could be a policy in place to prevent usb sticks working on work computers to protect intellectual property or to protect against virus transferance.
Sep 25, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Purchase 5 new verbatim 4gb when i plug it into pc the system found new hardware and installed . then it allow me to used two of the drive. when i plug it in the pc a msg appear, u need to format the disk...
You have to format the drives. If you put data on the drives using computer 'a' whos OS is MacOS and then you put the same Drive into computer 'b' which has windows, it may not recognise the file system/structure.
Nov 23, 2017 | Verbatim Store 'n' Go 4 GB USB 2.0 Flash...
I plugged my LG USB flashdrive into my laptop last night and laptop said that there was a USB malfunction. I had just used the flashdrive on a desktop. The flashdrive does not light up either. Is the...
Try the flash drive in another computer, if it works then backup your data.
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 22, 2009 | Electronics - Others
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Verbatim 4gb flash cant be recognised
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Move data from one computer to another with kingston 8gb data tra
When you plug in the Flash Drive to your old computer, it will show up in My Computer probably as Removable disk or "Kingston Data Travler". You want to open that link up and drag whatever files you need into that folder. After doing so you put the flash drive in your new computer and repeat the process except you drag the files out of the folder and onto your desktop or a folder of your liking.
Jan 31, 2009 | Kingston (SDCZ2-512-A10-KT)...
How do i use my new sandisk cruzer?
insert the flash drive into your computer and wait for it to be recognised by windows. Once it has been recognised and installed it will tell you that it is installed and ready to use.
The just go to wherever it is on your computer that you have your photos stored, select your photos right click and click on copy, then go to 'my comptuer' and double click on your flash drive to open it and paste your picture there.
Or select your photos, right click, select sent to:- and send to your flash drive, it may be recognised as removable storage.
Nov 17, 2008 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Computer won't recognise camera to download images
** Problem Solved **
I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
Feb 13, 2008 | Cameras
Problem with USB Flash
It is possible the memory stick is faulty. Are you using xp or vista? If so it should be recognised instantly. I bought one the same a couple of weeks ago, and it recognised it instantly, and I'm using xp.
Try it on another computer if possible, even where you purchased it. Just tell them you think it's faulty. If it works on that computer then you have a problem with either your usb ports or you have a virus.
Jan 01, 2008 | Electronics - Others
Computers & Internet Logo
David Payne
David Payne
