Question about Husqvarna Designer I
I had my bobbin winder replaced a couple of years ago. I never checked to see if it worked because I had two other machines. Not only doesn't it work, it's not even installed correctly. Is this that difficult to fix? I don't want to take my machine for repair in Floriddduuuuhhh anymore. They're incompetent and inept.
  • Pamsquilt Oct 16, 2010
    In what way "doesn't it work"? How can you tell it is not installed correctly? Could you describe just what it looks like and what is/is not happening in more detail please?
    Problem Solver:
  • 10 Answers
Hi roogm, Now that's a shame that you waited two years to find out that your bobbin winder wasn't fixed properly nor even installed properly. They should have demoed that to you as soon as you picked up that machine. No duh! We're not talking about a $100. machine here!
Well my dear I hate to tell you but this is not an easy fix without taking the whole machine apart to get to that part. I don't know if your machine is still under warranty or maybe you've purchased an extended service contract if they do that there in Floriddduuuuhhh. And I hate it when you're not in an area where you don't have a good dealership that can help. I'd help you out with that but I live all the way over here in Hawaii.
All of our Sewing machine Dealerships here are under 1 owner, And I mean all of the brands of sewing machines except for Home Sewing machines. So he's got the market covered here and it's not cheap to repair anything!! I learned how to work on my own Designer 1 from working in one of the Viking stores here so I pretty much can service my own so far. You think maybe if you took it back in they might still be able to help out with the situation? I'm sorry I couldn't of been of more help. It's pretty tricky taking the machine apart also if you don't know what you're doing. Drop me an email at- kats2sew@hotmail.com if there's anything else I can do. Have Happier Sewing Days!!:-) Kathy
Posted on Nov 24, 2010
I have the Bernina Artista 180. It is not recognizing when I turn the bobbin winder on. Any suggestions?
For a quick fix and until you can get your machine serviced, pick up a Sidewinder bobbin winder (check to make sure your bobbins will work since the larger Bernina bobbins may not). I purchased a Sidewinder a few years ago and use it all the time. Saves wear-n-tear on the machine but also lets you quickly wind multiple bobbins without having to unthread your machine. Most Sidewinders are battery operated, but mine also has an AC adaptor for electrical usage too.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Sep 24, 2017 | Bernina Sewing Machines
Bobbin on Bernina 807 won't wind?
Please follow the logic checks and possible corrections:
1. Check the winder shaft for a sticking or a stuck condition. If stuck or sticking, add a drop or two of mineral spirits to the winder shaft and the winder support bushing. This will generally release the winder shaft.
If the winder shaft becomes free wheeling, clean off excess solvent and apply a drop of Bernina machine oil which is typically a class 68 machine oil. You can also use a common white mineral sewing machine oil.
Do not use WD-40 or 3 in 1 oil!
If WD-40 had been used prior to the winder seizure then you'll know why....Removing sticky WD-40 residues requires further measures.
2. If only the rubber wheel has hardened, you will need to replace the winder hub with a new hub and replaceable winder ring or the entire winder can be replaced. There are some very good after-market parts available online.
3. If the winder parts are good and you are describing a condition where the hand-wheel will not release so that the machine drives while trying to wind a bobbin, this would requite another question and detailed answer... SewTechnical Home
Jan 25, 2015 | Bernina Sewing Machines
Why does my Singer 3820 bobbin winder not disengage the sewing foot now?
sounds like the clutch is stuck I would take it into a repair shop
Aug 05, 2014 | Singer 3820 Mechanical Sewing Machine
Bobbin winder shaft wont spin
If you take it apart, you'll void the remaining warranty. The usual cause is not getting the door open completely and/or thread wrapped around the spindle.
You'll also want to take a look at: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=CS8150
Feb 11, 2014 | Brother CS-8150 Computerized Sewing...
Elna lotus tsp
I would really suggest having the machines bobbin winder checked at a sewing machine repair shop..
Jul 10, 2013 | Sewing Machines
My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
When winding a new bobbin, the bobbin itself is breaking in two. (splits in half, the top and bottom split apart). It seems logical that there is too much tension perhaps. It happens almost at the end...
There's really no way to increase the bobbin winder tension. Check to see that you have it threaded correctly for bobbin winding. There should be just a little bit of drag on the thread as you pull it over to prewound it on the bobbin.
May 03, 2011 | Brother PE-150V Computerized Sewing...
The bobbin winder will not spin
You model is the same as mine. The bobbin is wound by a plastic gear behind the hand wheel. It probably broke like mine did some years ago. Check with your local repair shop or order it online.
Jan 24, 2010 | Riccar Sewing Machines
Bobbin Winder Works--Stitching Does Not
The second microswitch that is located just to the right of the bobbin winder stop tells the machine that it is set to wind a bobbin.
If the machine does not indicate that the bobbin winder is engaged, the second microswitch is not the problem. The bobbin winder itself is what shifts the clutch. If it is pulled downward, the clutch is disengaged and the upper shaft does not turn. Place your thumb under the bobbin winder, push it upwards and the clutch automatically re-engages and the shaft will turn.
Be very careful with the touch screen cable with the front cover off. If it has the older style cable on it, they are very delicate when releasing and reconnecting. If you put the front cover back on and the touch screen does not work, this will be the most likely problem. You will need to have the touch screen replaced.
You need to get your bobbin winder turned off first, then worry about the stop contacting the thread. If the stop is not tripped, then it is in its normal position and everything should work fine.
When not filling a bobbin, simply raise the bobbin winder and you should be ready to sew. Look at the opening around the winder shaft in the front cover and you will need to have it up and to the right. Just push the shaft with your thumb.
Mar 25, 2009 | Husqvarna Designer I
Sewing Machines Logo
44 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
