GE Model wwsr3090t5ww. Agitator and drum turn together. What is broken?
  • Washing Mach... Master
  • 3,361 Answers
The transmission is bad and must be replaced.
Contact a GE service company as most of these transmissions are under 10 year warranty.
Posted on Oct 16, 2010
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
How do I get apart. The agitator is broken
The fabric softener comes off, pull straight up. Then the upper agitator unbolts from the top. Be careful to properly align when you put it all back together.
Jan 09, 2011 | GE WBSE3120B Top Load Washer
WJSR2070B2WW AGITATOR REMOVAL NOISY IN SPIN . AGITATOR SPINS BUT TUB DOESN'T.
got help on another site for free that told how to remove agitator which allwed me to see the metal part that connects inner drum to transmission had completely broken into two seperate parts. will replace.
anks
bobth
Dec 06, 2009 | GE Washing Machines
Agitator does not turn in my GE washer, it is 3 years old
Sounds like the agitator dogs have aged and broken apart. these are easy fixes at about 5.00- 10.00 and require the removal of the one bolt that holds the agitator down. After confirming this, take your washer model number and make to parts store and get replacement dogs. Hope this hepls..
Oct 27, 2009 | GE Washing Machines
GE washer model WJRE555OH1WW - agitator free-wheels.
First make sure the inner part of the agitator is not brocken.
Remove the soap cap from the top of the agitator and with a torch, look down into the shaft. There is normally a nut which secures the agitator to the gearbox shaft. If the plastic around the nut is broken then the agitator moves freely.
There may not be a problem with your gear box, then and relatively cheap to replace agitator.
goodluck.
Ash
Oct 22, 2009 | GE Washing Machines
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
