Question about Husqvarna 21" Walk Behind Lawn Mower HVL 7021RC
The pull cord on the mower is frozen after several times of pulling it.
  • 903 Answers
The drive shaft might need to be lubricated. If the shaft won't turn, you won't be able to pull the cord.
Try turning the mower on its side (making sure all of the caps are on so you don't spill gas or oil) and lubricating the drive shaft with WD-40 or 3-in-1 (or another similar lubricating oil). Coat the shaft where it disappears into the housing of the mower, and turn the blade by hand -- carefully, so you don't cut yourself -- to work the oil in. After turning the blade a few times, add some more oil to the shaft and turn it more. It should become easier to turn. Then turn the mower back onto its wheels and try the pull cord... it should pull easily now.
Posted on Mar 25, 2011
  • Sabrina Jul 02, 2013
    Thanks so much for the help. I just knew we blew the engine, but I tried this first and it works like a charm.
Brand new craftsman 190cc lawnmower pull cord will not pull out
New mowers some times comes with a safety block on the blade and this has to be removed before you can turn the blades
Jun 30, 2014 | Craftsman Garden
I have tried to post my question several times, asking how to change the pull cord on my Poulan 625 series lawn mower, it hasn't posted and I can't seem to get an answer.
did this break at the pull handle? if so you will still be able to re-use the same cord.
you have to first remove the pull mechanizum from the top of the engine. turn it upside down and get the old pull chord off 'If it has broken at the engine end of the cord. You will find the end of the cord inside, remove it with a pair of pin nosed pliers.
If broken at the pull handle remove the broken and of the cord from the back side of the handle. There will be a knot tied in either end. Assuming you still have enough pull cord . Cut the broken end so it is not frayed slip it through the pull handle and tie a simple knot & make it tight with some pliers.
re wind the spring by hand winding the cord back into the spool.
now you need a small zap strap to hold it all in place until you reinstall the pull mechanizum on top of the engine.Once you have done this cut the zap strap off and retrieve it as you do.
Hint* "with only 2 hands" I have used pin nosed vice grips to hold back the spring while I tie it off with zap strap or stiff string.
If the cord if broken at the engine end you will need to line up the cord input with the cord journal and hold in place while you try to feed the cord back through. Hint* use a smaller peice of wire to feed through the opposite direction and wind it around the cord several times so you can pull it through to the inside of the pull mechanizum and tie a knot. Good luck
Oct 12, 2013 | Garden
Pull rope on sears 5.0 lawn mower pulls hard sometimes or you pull the cord and the spindle does not always turn. I guess it's not catching all the time. What can I do for it ?
If mower has sit outside for a while the works in the recoil may be rusty and dry. Try some oil in all the working parts. See if that works for you.
Aug 02, 2012 | Sears Garden
Hi I just purchased a mower. Briggs 158 and the pull cord is frozen. any ideas?
try taking the spark plug out and pulling the cord with it still out you may be oild fouled. if it pulls then continue pulling for several minutes and return plug
Jul 17, 2011 | Garden
When I pull the pull cord on my snowblower it doesn seem to engage the starter. the cord retracts after I pull it. It was working fine when I used it yesterday, then today it doesn't seem to catch when I...
Hello, W/D here.
Most of the recoil starters have ball bearings in them, and the centrifugal force that you apply pushes the balls out where they engage pawls and allow the flywheel to be rotated. Since your's is on a snowblower, you may just be stuck, or moisture could be in the mechanism, freezing the ball bearings in place.
The quickest thing to try: Rap the recoil mechanism in the middle of the top, with a rubber hammer. You want to jolt it, without denting it. Try to pull the cord and see if it engages. You can repeat this several times, but try not to dent it.
If the machine is outside, and you believe that the mechanism may have frozen, you can apply heat to it with a hair dryer, and then rap and try.
Try these out and repost if the problem persists.
Best regards, W/D
Feb 03, 2011 | Garden
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Nov 08, 2009 | Toro Garden
New lawn boy mower pull cord will not pull. Worked first 2x
Did you check the oil before you ran it. They usually come dry and you have to but oil in before running. Sounds like motor might be blown.
Aug 14, 2009 | Garden
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Husqvarna 21" Walk Behind Lawn Mower HVL 7021RC Logo
648 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
