How do i reset?
To reset the ink absorber is almost full:
1. Remove print head by following manufacturer procedure (available at www.canon.usa.com.
2. Turn off printer.
3. While pressing the Resume/Cancel button, press and hold the Power button. (Do not release the buttons. The Power LED lights in green to indicate that a function is selectable.)
4. While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
5. While holding the Power button, press the Resume/Cancel button 2 times. Then release both the Power and Resume/Control button.
6. When the Power LED lights in green, press the Resume/Cancel button 4 times.
7. Turn printer off. Then replace the printer head using manufacturer's procedure available on line.
8. The printer is now reset and you are ready to print.
Larry
Posted on Aug 18, 2009
You have to refer to canon service centre because they don't give the software for resetting it
Posted on Jul 24, 2008
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
SOURCE: canon pixma ip8500
You know, I think this is the most common problem in all Canon Printers and yet Canon must do something about this. In my case I already have 3 Canon Printers The first 1 is Canon Pixma MP160 and the problem is "The Ink absorber is Full" then my 2nd is Canon Pixma MP145 still the same problem occurs my 3rd is MP145 also and I know sooner or later I will be facing the same problem.
Sometimes I think the Canon's Printer is Disposable it won't last for a long time. I just hope I can find the right solution to this problem, so that i can fix my printers. I have lost 2 already and maybe sooner the other one will follow.
Posted on Jul 20, 2008
SOURCE: Waste ink absorber - Canon ip8500 photo printer
replace the Waste ink absorber
SOURCE: Ink absorber full Canon MP210
(11/24)
<Service mode operation procedures>
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
(11/24)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print See APPENDIX 1:
SHIPMENT INSPECTION
PATTERN 1: PRINT
SAMPLE
2 times Green EEPROM print See APPENDIX 2:
EEPROM INFORMATION
PRINT
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
(12/24)
<Destination setting procedures>
At Logic board replacement, make settings for each destination.
button pressing
LED Destination Paper for defaulte setting
0 time Green No change
1 time Orange Japan A4
2 times Green Korea A4
3 times Orange US/Canada Letter
4 times Green Europe A4
5 times Orange Australia A4
6 or more times Returns to a menu selection A4
<Waste ink counter reset procedures>
At the waste ink absorber replacement, reset the waste ink counter for the replaced waste ink absorber.
Setting operation for the waste ink counter (The counter setting value is selected by pressing the Reset button.)
The number of the Reset button
pressing
LED
0 time Green Reset the main waste ink counter to 0%.
1 time Orange Reset the platen waste ink counter to 0%.
2 times Green Reset the Main & platen waste ink counter to 0%. (Reset
collectively.)
<Button / LCD checking operation procedures>
At Operation panel unit replacement, check the button / LCD.
1. When pressing the Stop button two times, the machine will be moved into an LED confirmation mode.
2. As often as the Color button is pressed one time, each LED is lit one by one, and the machine get in the mode in which each
button is acceptable.
3. As often as each buttons on the panel is pressed from the left to the right, the displayed number is counted up.
Pressed button Display
Maintenance 1
Fit to Page 2
SCAN 3
Paper size 4
+ 5
Black 6
Color 7
Stop / Reset 8
On / Off 9
4. When all buttons are pressed, [1] will be displayed. Then, LED[8.5 x 11 Plain Paper] and LED[8.5 x 11 Photo Paper] will be lit on
the panel, and the machine will be in a service mode menu selection mode.
Posted on May 20, 2009
SOURCE: Canon pixma ip8500, on third print head in about 4
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Posted on Oct 01, 2010
Testimonial: "Thanks Ronil. I had a feeling that this might be the case. Don't know if I'll buy another Canon though - this one has gone through 3 print heads."
Apr 07, 2016 | Canon Office Equipment & Supplies
Nov 19, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
Oct 01, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Sep 25, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Sep 13, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Jun 03, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Apr 15, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Oct 13, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
Oct 24, 2014 | Canon PIXMA iP8500 InkJet Photo Printer
2,576 people viewed this question
