Question about Kenmore HE2 Plus Front Load Washer
Rubber door seal has a small tear. - Kenmore HE2 Plus Front Load Washer
    President:
  • 1,430 Answers
You will probally need to replace it, here is a link that will help Replacing a door seal
I have used 100% silicone to plug the holes. This has held up for several weeks without leaking. I clean the area with alcohol and rub a layer of pure silicone thru the tear trying to get it on both sides. Try to keep the inside layer not to thick so clothes do not get hung up on it, let it dry for 24 hours and it should hold.
Posted on Oct 16, 2010
3 Suggested Answers
apart4u
  • 213 Answers
SOURCE: LG Washer leak, small tear in door seal
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
  • 70 Answers
SOURCE: miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Posted on Jul 08, 2010
Why is my whirlpool deut washer tearing clothes
Check the little holes around the drum, I have seen pins and needles get stuck in these and cause lots of damage. I would replace the seal.
Apr 10, 2013 | Washing Machines
Door seal leaks
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If no obvious rips or tears are found, it is also common for the bellow to stretch over time and no longer provide a good seal around the door glass. Make sure you check to see if the bellow is sealing properly all the way around the perimeter of the door.
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Apr 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How can I replace front load washer rubber seal in the door
Hello, W/D here.
Fit the seal to the door, then work the band into the groove, with the intention of placing the spring on last. Work it around and on until you get to the spring. With a small screwdriver (or popsicle stick, or similar) carefully lever the spring over the lop and into place. The important part is to be careful not to tear the rubber.
Best regards, --W/D--
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
HI my ge adora washer is leaking and it looks like the rubber rim has 2 small u shaped tears about 3/8" in it what can I do,
You could try sealing the tears with silicon sealer, it might work, otherwise you will need to have a new rubber seal fitted.
Dec 16, 2010 | GE WSXH208A Front Load Washer
Miele front loader rubber door sela has small tear
No.
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
WATER IS LEAKING OUT OF DISHWASHER DURING CYLE
could be one of 2 problems. 1) the rubber gasket seal has a small tear or hole... it doesn't take much. or 2) the door latch is loose or broken
Mar 13, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Leak from base of machine but only when emptying in spin cycle.
Reove lower rear panel, and check for leak around pump and hoses, also check the door seal, and look for any small hole or tear in the rubber.
Please rate my soution.
Thanks.
Nov 09, 2009 | Hotpoint First Edition WMA20 Front Load...
AWM 8143 front loader- rubber door needs to be replaced
Yes,it is called a bellow.If the tear is small enough and just on the front rim of the seal try gluing it with super glue,it will get you by till you can get it replaced.
Sep 07, 2009 | Whirlpool AWM8143 Front Load Washer
Jul 04, 2009 | LG WD-1080FD Front Load Washer
Small crack in rubber seal
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Aug 06, 2007 | Bosch WFR 145 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
956 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
