Question about Canon imageRUNNER 105 Printer
Hi i have canon ir 105 gives error E 69 i replaced transfer corona unit the machine made 140 copies and the error comes up agin please any help
    ???? ??? Feb 06, 2014
    check and clean properly. again come back. check A.c tranformer( ac power supply)
    me aksha....
5 Suggested Answers
SOURCE: USA - COPIERS - IMAGERUNNER 2230 Copier: canon IR 2230 r giving me an error E000024-0001...
eroor 000024-0001 error is found in cannon ir 2870 machine, how is solve the problem
Posted on Aug 25, 2011
SOURCE: Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Posted on Apr 09, 2009
  • 23 Answers
SOURCE: Canon IR 105 error code
that error can be related to the transport assy that you pull out not going back in properly. make sure you push it back in firmly so it locates into the connectors in the rear properly. the manual says a problem with the primary corona unit but my experience is the tray. tis is a common problem even on the new models ir9000 series that use the same set up.
Posted on Nov 01, 2010
azzoom_in10
SOURCE: Hi canon IR 6800 CN
canon ir 6800cn error code e000100-0002 solution
Posted on Nov 13, 2012
I have canon ir8500, when i copy document, it showing E00069-000.
Error- 69, just try to clean the transfer unit, and change the all the corona wire,
Sep 03, 2011 | Canon imageRUNNER 8500 Copier
My canon ir 5570 print quality not set print quality is very light
lets try first with technical side!
When was, last time, preventive maintenance service?
You need on regular base:
- clean optics ( beneath copy glass too )
- replace charge corona
- replace transfer corona
- clean/replace paper pick-up, feed and separation rollers.
In most cases the problem will be solved with new transfer corona assy.
Jul 06, 2010 | Canon imageRUNNER 5570 Copier
My ir 400 gives a white spot
something could be blocking the primary chargeing corona wires/roller. i see it a lot on the ir 5000 when the primary corona assmbly cleaning pads get stuck half way through the cleaning cycle.
Jun 16, 2010 | Canon imageRUNNER 400S Copier
White stirkes in canon iR2016 photocopying result
It is either the drum unit or developer unit or transfer roller. if your counter is 150 000 copies change dev unit and transfere roller.
Oct 03, 2009 | Canon iR 2016i Black and White Copier
Intermittent E0061-0001 on a IR6570 canon
Have you tried to replace the Primary Charge corona unit? How about the rear block for the primary? Try to blow it out.... I did see in the book to try to run DPC in service mode... I also remember on older Canons that some times the wire ties may cause a problem... Also, you say that you are getting background... Is the laser good? Come to think of it I had a IR-5000 do the same thing and it turned out to be the rear corona block for the primary & transfer corona units... Good Luck
Mar 01, 2009 | Canon imageRUNNER 5570 Copier
Canon NP 6218 B&W Copier
try also to change or to service the corona units both the upper corona in the drum unit and the the transfer corona assembly unit down the drum. ok try your best.
Sep 01, 2008 | Canon NP 7130 Black and White Copier
Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
Jun 24, 2008 | Canon imageRUNNER C3220 Color Copier
About error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
Dec 03, 2007 | Canon imageRUNNER 5000 Copier
Canon ir 8500
E010 relates to a main motor fault. A specified amount of rotations has not occurred within a set time. Check motor, see if it turns by hand. If not, inspect and/or replace. Check belts and gears for wear/damage, replace as necessary. E065 relates to a primary charging problem. Suspect primary corona arcing, corona wire broken, High-Voltage PSU may be unservicable, black developer unit may be pulling HVT down. How many copies has each machine done? Recommend calling an engineer, parts are probably required.
Sep 09, 2007 | Canon imageRUNNER 400S Copier
387 people viewed this question
old marine
old marine
