Question about Estate TAWX700JQ Top Load Washer
Water is dripping into the top of the tub when not in use
    President:
  • 1,430 Answers
The water inlet valve has failed. They tend to get debris inside and then do not seat properly. Don't bother trying to clean it out just replace it. While your in there clean out the screens in the hoses. Here is a link that should help water inlet valve replacement
There are also links for disassembling if needed at the same site.
Posted on Oct 16, 2010
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
I have a Model GSL9365EQ2. It has a slow drip
Take the drain hose out of the regular drain and lower it to gravity drain into a bucket, pan, or floor drain if available. Turning the water off should not have prevented the machine from starting. The drip is likely coming from a leaking solenoid water valve at the rear of the machine where the hoses connect. Replace the valve assembly after removing the cabinet top and maybe the cabinet back panel. Make sure to remove the power if you are going to do the work. Hope this helps!
Mar 26, 2010 | Washing Machines
Washer leaks out of the bottom. checked drain hose it is not plugged, checked hot and cold water hoses they're ok.
REMOVE THE TOP OF WASHER AND CHECK THE WATER INLET VALVE. I HAVE DONE EVERYTHING AND FINALLY DISMANTLED THE WASHER UNTIL I FOUND THE HOT WATER INLET VALVE WAS LEAKING FROM THE TOP AND DRIPPING DOWN THE TUB AND ENDING UP ON MY FLOOR. IT WILL DRIP EVEN WHEN THE WASHER IS NOT ON DUE TO THE PRESSURE BUILT UP ON THE VALVE.
Oct 25, 2009 | LG WM2688HWM TROMM SteamWasher
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Water dripping into the tub. Whirlpool top loading washer
You just need to replace the water vale.
The valve is not closing all the way when its off.
Sep 05, 2009 | Whirlpool Washing Machines
Water Dripping
you need a new fill valve, even if you ulplug the washer does it still drip? If yes then you do need a new fill valve. Just turn water off at the wall so your machine don't overfill.
Oct 28, 2008 | Kenmore 24032\24036 Top Load Washer
Water drips in the tub
a faulty inlet water valve on the machine itself, just not seating properly allowing water to flow after shutting off, turning off water inbetween washes a good temp fix as well as a good habit to get into
Jul 09, 2008 | GE WPGT9350C Top Load Washer
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
