Question about Whirlpool Refrigerators
We have a whirlpool fridge: Model ET19RKXGW03 Serial # EK4822063 with a mfg. date of 11/2000. We first noticed it wasn't cooling good, then noticed the back wall of the freezer is covered with frost. Almost 3/4 inch thick at some places. What's the problem?
  • Cherilee Holderman Oct 20, 2010
    This is the most helpful advice I have received. Thank you! I will check out these areas.
  • 567 Answers
If yours isn't a self-defrosting freezer, frost build-up is normal. But when the frost gets to be ½" to 1" thick, it's time for you to defrost it.
If you have a frost-free freezer, it shouldn't be icing up. What can you do if it is?
Freezers should self-defrost three times a day, due to a self-defrosting system built in to the freezer.
If its a frost-free freezer the ice could be caused by the following:
1. Evaporator fan not running.
2. Defrost timer not working.
3. Defrost heater is bad.
4. Defrost saftey control is open
5. Drainline is plugged, not allowing condensation to drain and causing freeze up.
It could be the seals, the rubber gasket around the edge of the door is leaking and needs either cleaning or replacement.
If something is wrong with the self-defrosting system, the freezer will still continue to try to cool itself off.
Eventually, the evaporator coolers will become covered in frost and will not work properly.
Posted on Oct 17, 2010
  • Anuj Joshi
    Anuj Joshi Oct 20, 2010
    Your welcome Thanks! :)
  • Whirlpool Master
  • 1,711 Answers
The ice should have been melt automatically. The auto defrosts is control by the Timer, defrost
Part Number: AP3110896 made by WHIRLPOOL, part no 4 at the link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=263874&diagram_id=114655#d114655
And is melt down by the use of the Heater Part Number: AP3859446 made by WHIRLPOOL, part No 4 at link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=263874&diagram_id=114656#d114656
The above heater is switching off by a safety thermostat Bimetal defrost Part Number: AP3108454 made by WHIRLPOOL, part 8 at same above link.
So these three parts must be check which is faulty in some case all three can be, and we have the build up of ice.
So first by use a hair dryer melt down the ice manually.
Second use and ohmmeter and check if the heater has a resistance of about 20 Homs up 150 Homs aprox. If you see infinity or thousand of ohms then heater need to be replaced.
Timer and Bimetal have to be check by supervision see when the heater switch on and inspect for how long it stay on. If the time for the heater On is less than 20 minutes then we suggest replacing defrost timer.
Finally if after replacing the timer then you still have some ice remain then go on replace also the bimetal and that's it. Problem solved.
Posted on Oct 16, 2010
  • 4,793 Answers
The problem could be that where the pipes go into the freezer frost has started and has since grown with age/humidity of the room its in.do a full defrost/dry out(do NOT use steam/sharp objects)then start up as normal.should work fine after.when your doing the defrost you will see some clear(er)patches these areas may need extra insulation when dry.
What is the mfg. date ?
The mfg date or manufacturing date is the day that a product was manufactured.
May 02, 2016 | Optics
(S)EAJM121146
Without knowing the brand looking up models mfg. dates is difficult.
did you check back or bottom for Mfg. date? Usually near the serial number. Sometimes the mfg. date is contained in the serial number. You may also try googling the manufacturers name and view their contact information.
Jul 06, 2014 | Computers & Internet
Cubic feet of 1999 kenmore refrigerator model 70289990
How many cubic feet is my fridge ...Kenmore model # 106.70872990
Serial # EJ4814023
MFG date 11-99
Sep 15, 2013 | Kenmore Refrigerators
Am trying to determine if my washing machine is still under warranty
Is it under one year old? Then it is still under basic warranty parts and labor.
Dec 06, 2011 | Whirlpool Washing Machines
Hi I have a whirlpool fridg. m/n ET19RKXGN00, S/N EH1230820 with a MFG date of 03/98.It's a top freezer model and I have water dripping from the top of the fridge.almost all the time. I removed the plastic...
The last tip will help you out there...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Whirlpool Refrigerators
Bought this house with the fridge. It is a
Good day,
Get the complete model number and serial number off the machine and go here.
http://www.appliance411.com/service/date-code.php
Dec 12, 2009 | Refrigerators
Kenmore 106.56566400 cooling problems
for most kenmore refrigs there is a manufactureres date right on the model number tag. I am a sears service tech and I can assure you they dont need to know the previous owners info in order for you to get warranty service. if you cant find a mfg date on the model tag then go to this site and input your serial number in the whirlpool box and it will tell you when it was. manufactured.
Btw 241.00 would be about the price of the compressor alone with labor and all additional needed parts thru Sears it will run you close to 650-700 to repair. Thanks Peyton
Mar 11, 2009 | Refrigerators
Water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
May 09, 2008 | Refrigerators
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
163 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
