Question about HP Computers & Internet
Try to get a set of recovery disc - HP Computers & Internet
  • 66 Answers
Contacthp/compaq support... sometime you can get recovery for $7.00 or $15.00
http://welcome.hp.com/country/us/en/contact_us.html
Posted on Jun 03, 2008
How to restore a toshiba satellite a135-s2286 notebook without cd?
the f8 function is only to try and remedy boot problems. the recovery option you're getting is to restore if you have already made recovery discs.
if you have a recovery partition on your hard drive you should be able to access it when you boot up. before starting your laptop press and hold 0(zero) key and power on the laptop. once it starts you should get a screen with 3 options then choose option 1 to get back to factory restore.
Nov 11, 2012 | Toshiba Satelite A135-S2286 Notebook
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
I need to reboot my n10 notebook to factory settings,please help
Hello there,
Newer Toshiba laptops usually have the ability to create recovery discs that will let you recover to "factory settings." Try this:
1. Click Start
2. Select All Programs
3. Select Recovery Disc Creator.
Recovery Disk Creator
4. Within the Recovery Disc Creator select Create
5. When prompted enter the first blank DVD and select Ok
6. When prompted enter the second blank DVD and select Ok
I hope this helps. Thumbs up if you think so.
May 07, 2011 | Toshiba Computers & Internet
Restore to factory settings
If you want to go back to the factory settings. First you must check if you have the recovery disc provided by you're laptop manufacturer. There is an instructions included on the CD case. Also, some models of laptops has a HDD recovery partition, where in you won't need a recovery disc. Some laptops to enter setup, you may press F12 and select the HDD and it will enter the recovery partition. Try to check for your recovery disc or the key to enter the setup for your laptop brand.
Hope this helps.
Mar 16, 2011 | Computers & Internet
I was trying to create the Recovery Management disk but everytime I try to burn the CD it keeps ejecting. I would really like it if you could provide some help. I recently bought this E-Machine computer...
Welcome to Fixya
Please see procedure below on how to create recovery disk. Let me know if smae thing will happen.
  • 1
    Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
  • 2
    Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
  • 3
    Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
  • 4
    Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
  • 5
    Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
  • 6
    Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
  • 7
    Set up Windows Vista with your own personal settings.
  • Thank you for using Fixya!
    Dec 04, 2010 | E-Machines emachines (emachinees) CD-ROM...
    Toshiba laptop a105-s4034
    You need to set your CD/DVD/CDRW Disk Drive to Boot First. If the Second set of Recovery CD's don't work, Then they are the Wrong one's for that unit.
    Feb 12, 2009 | Toshiba Satellite A105 Notebook
    Can't extract files on System Recovery Disc 4 for Compaq Presario model 6350US
    At this point, you can try to clean your disk # 4 and see what happen,
    or try to make a copy of disk # 4 (if you can copy the disk) and try again.
    or
    1) Contact your customer support and ask for a new set of disks.(or only # 4)
    or
    2) Boot your computer with another OS disk (win XP)
    or
    3) Boot your computer with some utility disk
    Oct 19, 2008 | Gateway MX6421 Notebook
    HP MEDIA CENTER 864N Desktop PC&p RECOVERY CD
    NOTE: Most HP and Compaq desktop PCs that ship with Windows Vista and XP do not come with recovery discs. Instead, they use a hidden space (partition) on the hard drive to store the recovery information. Using a hidden partition provides a convenient, more stable recovery solution.
    Step 1: Create a set of recovery discs or a recovery DVD
    To create the recovery disc set, Click Start , All Programs , PC Help & Tools (or similar), open the HP or Compaq Recovery CD-DVD Creation software, and follow the on-screen directions.
    If you cannot create recovery discs or your discs have become damaged, continue to the next step.
    Step 2: Order recovery CDs on the Web
    If you are not able to create a set of recovery discs, you may be able to order a set of replacement discs from HP. HP maintains a stock of replacement recovery discs for several years after the product has been released. However, because of licensing restrictions, HP is only able to provide these recovery discs for a limited time. If your computer is several years past its warranty period, HP may not be able to supply replacement discs for your computer. If this is the case, you can install a new operating system that meets the minimum system requirements of your computer, or, alternatively, upgrade your computer hardware.
    To find out if HP has recovery discs that you can order and to order them from HP, use the following steps:
    NOTE: The steps in this section apply to United States and Canada. For Europe, Middle East, and Africa please refer to the HP support document Europe, Middle East, and Africa - Statement on the Availability of the Recovery Software on CD . For other countries/regions, contact your local HP support center for information about obtaining recovery CDs.
    Go to the Software & Driver Downloads page .
    Enter the product number or model name for your computer into the field provided.
    Figure 1: Product name/number field
    Click the operating system link (the version of Windows that came with your computer).
    Figure 2: Example of operating system link
    Find the Recovery Disc ordering section and click the link to start the ordering process.
    NOTE: Before trying to order, make sure that you have read the important "Read this..." information listed in this Recover Disc ordering section.
    Note: - If the link to order a recovery disc set is not available, there may not be any more sets available for purchase. HP cannot create recovery discs that contain a version of Windows that has been obsoleted by Microsoft, such as Windows 95, 98, and Me. Some recovery disc sets may have run out of stock and may not be available to order.
    Figure 3: Recovery disc ordering links
    Follow the directions from the "Read this...” article and from the ordering pages to complete the ordering process.
    NOTE: The ordering pages use a secure connection to protect your privacy.
    If you cannot create a recovery disc set and you cannot order a recovery disc set from HP, go to the next step.
    Step 3: Contact Support
    If you have tried the steps 1 and 2 and could not create or obtain a recovery disc set, contact HP Customer Care . HP Customer Care may be able to send out new discs or replace defective versions depending on your situation and availability.
    Jul 21, 2008 | HP Computers & Internet
    Computer virus ruined my tower, hp pavillion s7320n, prod. #:EP140AA. I need a recovery disk? Drivers disk? And a lot of technical help. Marco
    If you are not able to create a set of recovery discs, you may be able to order a set of replacement discs from HP. HP maintains a stock of replacement recovery discs for several years after the product has been released. However, because of licensing restrictions, HP is only able to provide these recovery discs for a limited time. If your computer is several years past its warranty period, HP may not be able to supply replacement discs for your computer. If this is the case, you can install a new operating system that meets the minimum system requirements of your computer, or, alternatively, upgrade your computer hardware. To find out if HP has recovery discs that you can order and to order them from HP, use the following steps:
    NOTE: The steps in this section apply to United States and Canada . For Europe, Middle East, and Africa please refer to the HP support document Europe, Middle East, and Africa - Statement on the Availability of the Recovery Software on CD . For other countries/regions, contact your local HP support center for information about obtaining recovery CDs.
    1. Go to the Software & Driver Downloads page .
    2. Enter the product number or model name for your computer into the field provided. Figure 1: Product name/number field c00772934.gif
    3. Click the operating system link (the version of Windows that came with your computer). Figure 2: Example of operating system link c00772003.gif
    4. Find the Recovery Disc ordering section and click the link to start the ordering process.
      NOTE: If the link to order a recovery disc set is not available , there may not be any more sets available for purchase. HP cannot create recovery discs that contain a version of Windows that has been obsoleted by Microsoft, such as Windows 95, 98, and Me. Some recovery disc sets may have run out of stock and may not be available to order. Figure 3: Recovery disc ordering links c00772004.gif
    5. Follow the directions from the "Read this.." article and from the ordering pages to complete the ordering process.
      Thanks. Please take a moment to rate this as FixYa.
      Thank you.
    Jul 07, 2008 | Computers & Internet
    Computers & Internet Logo
    14 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
