Question about LG WM0642H Front Load
Wont drain for spin cycle - LG WM0642H Front Load
Hi.Mi WM0642HW washer is not draining water.I took it apart ,checked all hoses ,removed drain pomp,plugged it to 120 it's working fine.Put it back together and it still not draining water.No error code on the panel.any guess? Thank you.
Posted on Jan 13, 2012
    President:
  • 2,468 Answers
In the previous statement i meant to say,if its plugged and cant drain then it wont advance to the spin cycle
Posted on Oct 16, 2010
2 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Wont drain or spin
I think simply your drain pump motor is stuck for what ever season. open it up and check. You will never get a spin condition if the water has not drained sufficiently.
Posted on Sep 14, 2009
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Spin cycle wont function wont drain
The pump is either clogged or burnt out. Check inside the pump hoses for a blockage first then try it again when cleared
Feb 13, 2010 | Whirlpool ET8CHEXSQ Dryer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washing machine wont drain or spin all other cycles work fine
you may have a timer problem just advanced your timer on click ahead when it happenes if it drains or spin replce your timer thanks from giles
Mar 14, 2009 | Washing Machines
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
LG WM0642H Front Load Logo
267 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
