My sony tv kdl-52xbr9 tv powers on and off every 5 sec when I power it on. it won't stay on. it just keeps cycling on and off.
  • 712 Answers
It might be the relay switches. Give it a check.
Posted on Oct 16, 2010
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
My TV does not power up,Sony KDL-52XBR9,it tries to trigger the relay on power supply board G7N 4 times(RY6101) then it turn to blinking red LED 10 times per cycle.Is it power supply fail?which part?
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 12, 2015 | Sony KDL-52XBR9 52 in. LCD HDTV
I have a Sony KDL-52XBR9 52
Most likely a contact problem or broken track on one of the flexi circuits coming off the LCD screen - Repair shop would recommend a new screen. Some people have bodged repairs by putting pressure (layers if tape) on offending flexi circuit - see AVS forums - but this is definitely not recommended and if you are not skilled then working in the back of a TV can be lethal. My advice always buy LCD TVs with a 5 year warranty (Richer Sounds, JLP or similar).
Dec 04, 2017 | Sony KDL-52XBR9 52 in. LCD HDTV
SONY KDL-40S4100 flashes 5 times
try to force on the tv un plug and use remote when tv iv completly off. and press display 5 vol+ then power and see if tv stays on and in service menu look for eror code .if tv stays on if it cutts off then one of lamp in screen is defective. its mean screen defective
Mar 01, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
TV will switch to standby and then just shut down. TV is less than one year old.
It sounds like a fairly common power supply problem but you should have time left on your warranty if it covered you for one year; if it doesn't, I'm disappointed in Sony. You need to call the service center as they may have information on a series problem that they are dealing with. Do it soon-
Dec 08, 2010 | Sony KDL-52XBR9 52 in. LCD HDTV
Sony KDL-52XBR9 power/standby LED blinking. TV turns on for a few second and then turns off.
This is either your LCD backlight, inverter/power board or both. Neither of which are serviceable by the consumer, unless a visual inspection of the power board shows swollen or ruptured capacitors. This you can do yourself and is the most likely problem. Just read the side of the capacitor and go to radio shack, or online to find the right replacement capacitor. When re soldering be sure your negative and positive leads are in the correct holes.
Mar 12, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Want to get a manual
Click Sony Support to download user manual copy for KDL-52XBR9 TV
and if model number is different, please let me know.
Thanks.
Nov 03, 2009 | Sony KDL-52XBR9 52 in. LCD HDTV
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
