Question about D-Link AirPlus DI-524 Wireless Router
Internet connection lost when wireless printer added to network
Hi, I have a desktop computer running windows xp, a Billion ADSL router connected to a D-link Airplus DI-524 wireless router and a Brother HL-2170w wireless printer. I want to be able to connect wirelessly with my laptop to the internet and also print wirelessly on the Brother printer.
After setting up the printer no connection was available to the internet.
The printer works fine though.
I connected the computer directly to the Billion router and the internet works fine also, the issue is with the D-Link router.
Am I just stupid and that it does not support both wireless connections?
Also, having installed the D-link so long ago I have forgotten my password to get into the setup page, it's not username: admin password:
Any help would be appreciated!
  • Anonymous Mar 22, 2014
    Changing printers. HP 8600 printer requests a password. I do not have one. THE ROUTER states to leave that area blank. Iannot connect to Mac calculator.
  • 59 Answers
For reseting the password of ur dlink router u have to press the rest button on the dlink router (genrallyit on the bottom or on the back of the router it is like a hole u have to use a pen or pin to reset the router back to its factory default settings after that password of the router will automatically back to admin or password login to ur router change the settings to static ip in the router so that u can provide the static ip of the other router to ur this router (example if primary router HL 2170 ip address is 192.168.1.1 then u will provide this dlink router the ip address as 192.168.1.5, subnet 255.255.255.0 default gateway 192.168.1.1 primary dns 192.168.1.1 now save the settings in the dlink router now the ethernet cable from ur other router will go directly in to the internetor wan port of this router. now connect wirelessly to any router both will work fine without any problem
Posted on Jun 03, 2008
2 Suggested Answers
  • 21 Answers
SOURCE: D-Link AirPlus DI-524 Wireless Router pass and username
Default IP: 192.168.0.1
Default username: admin
Default password: *blank*
Posted on Jan 22, 2009
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
Instructions on how to connect my laptop to my adsl modem wirelessly.i have a 5200g billion router which is connected to my router via ethernet cable.i have a lenovo laptop with bluetooth.
Billion's BiPAC 5200G R4 is an economical ADSL2+ Firewall Router with 802.11g Wireless AP ideally designed for home and SOHO users to enjoy rich firewall security, mobility, and faster speed when using ADSL Internet connection.enabling system administrators to easily fit this security router into existing network environment and manage the IP assignment without reconfiguring your laptop with wifi.
Jul 13, 2011 | Computers & Internet
Where do find my security key to connect to the internet..I,m trying to set up a new computer..Thanks
If you have access to a wireless computer that is already connected to and operating on your network, then you should go here and download this utility http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=Im-88880-1&cc=us&lc=en&dlc=en
and then run it. Once it fully scans, click on Show Advanced Tools in the bottom left of the window and select Retrieve WPA/WEP Key, it will be on the right side.
If you do NOT have a wireless computer available, then you need to loginto your router (sorry, but I do not know which router you have) and go to the wireless page. If you have WEP, just copy down the WEP key that has the radial button selected (green dot) and that is your key. If you have WPA, copy the Preshared key.
If you do not know how to get to your router setup, go to a computer that is conencted to your router by a LAN cord. Go to Start > Run and in the Run window type CMD. If you have Vista or Win 7, go to the Start Orb and just type CMD into the serch bar. In the command prompt window type IPCONFIG /ALL now look for Default Gateway (that's your router) and copy down the IP Address.
Now open a web browser utility and type that IP Address into the address bar.
Dec 15, 2010 | Computers & Internet
Intermittent wireless Internet access
The problem started after you added the additional devices. Now you probably have all of your devices using DHCP which means the router provides an IP Address for your devices. Change the devices to have a fixed ip address. You may have to check the router for the default internal ip address, but it is probably 192.168.1.1 as the gateway. With the PC and laptop go to the control panel, then network connections, right clip on the connection and select properties, then scoll down the window until you see tcp/ip connection, select properties from the tab options below and set the ip address of each machine to 192.168.1.10, 192.168.1.11 and 192.168.1.12. set the gateway to 192.168.1.1 and set the dns ip to 192.168.1.1. Now if you have a different gateway address, use that as applied above. Save the settings and retry your connections.
Here is way you are probably having problems, wireless networks will drop and reconnect more often than a cable connection. If you were using just a cable connection, there would be less of a problem. When DHCP is being used and a computer drops the connection, it could get a totally different ip assignment the next time (a matter of less than a second of time). When that happens the original connection is lost. By fixing the ip address to be static, any time you reconnect via wireless, it uses exactly the same address, thus maintaining the connection.
Try it out and leave feedback if it works for you, otherwise send me the results of the test.
Feb 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
Connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Jun 16, 2009 | NetGear DG834G 802.11G Wireless ADSL...
My laptop finds wireless router but will not connect to internet
Hi there. You may need to connect to the wireless network manually. What is the operating system running on your computer? If XP, you may follow these. (This is also applicable in other operating system, it may just vary a little) Right click the monitor icon showing on the system tray near the clock. Point the mouse in the icon and it will display the name if it is wireless network connection or network connection. Right click the icon and look for view available wireless network. If it is not showing, look for network connection. Right click and select "open network connection". Right click wireless network connection and select "view available wireless network" . Look for the wireless network you're trying to access or have connection.Highlight and click connect. If encrypted, you need to supply the pass key or security key twice and hit connect. It should allow you now to go online wirelessly. Please remember these, you should be able to go online wired. Make sure that there are other wireless computer connected to the wireless network you're connecting with and can go online wirelessly.
Hope this help :)
May 16, 2009 | Dynamode (R-ADSL-C4-W) Wireless Router
Cant connect to my wirelessmodem
Try running the cd that came with the router again, since you reinstalled windows, the configurations for the router have been lost. If this doesn't help let us know and we'll work on it from there.. good luck!
Mar 14, 2009 | Dell Dimension 3100 PC Desktop
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I have a Compaq PC with Windows XP and the flat I've moved into has wireless broadband - how do I connect to it?
You can use a wireless network to share Internet access, files, printers, and more. Or you can use it to surf the Web while you're sitting on your couch or in your yard. Plus, it's easier to install than you think.
There are 4 steps to creating a wireless network:
1.
Choose your wireless equipment
2.
Connect your wireless router
3.
Configure your wireless router
4.
Connect your computers
For Windows XP users, Windows XP Service Pack 2 is not required for wireless networking, but it does make things much easier. Service Pack 2 also helps protect you against hackers, worms, and other Internet intruders.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
wireless_connected.gifFollow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
wireless_chooseconnection.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Nov 05, 2008 | Compaq Computers & Internet
Wireless connection to internet
I just got it all working [new notebook running Vista], connecting to the net via the telkom 5102G - with a PC running XP connecting via LAN.
The 5102G comes ready configured with a network key / code [stuck on the back] so use that to connect to the router - once you've connected it'll come up with limited connectivity.
I then ran the firmware upgrade from http://www.telkomphones.co.za/5102g.htm
To do this, download and unpack the thing. In your browser, go to 10.0.0.2 [for the router config] and click on firmware and follow the instructions.
Once this is done - disconnect and reconnect the vista laptop connection. Open your browser and simply click on tools and uncheck the tickbox alongside "work offline".
I know that sounds ridiculous but that's exactly what I did and I'm surfing fine.
Now... just need to share files and printer and we're 100%.
Hope that helps.
Jan 16, 2008 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
625 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
