Question about Maytag MMV4205 Microwave Oven
Pluged in no power - Maytag MMV4205 Microwave Oven
  • 1,711 Answers
There is a fuse in the control side that might be blown out and need to be replaced
Posted on Oct 16, 2010
Now power when pluged into outlet
Have you tested the fuse which may be faulty
Mar 27, 2014 | Whirlpool MT4078SKB / MT4078SKQ 700 Watts...
Microwave model MMV5207BAW won't power up when pluged in. Outlet has power but microwave wont power up.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 14, 2011 | Maytag MMV5207BAW Microwave Oven
My miele microwave is blowing the house fuse once pluged in to power point. Any idea why?
Their is a live wire which contact to the metal body so it contact to the earth cable. This can be by a loose wire, a burn heating element or a burn motor. All the above can lead to direct contact of alive cable mean power cable to earth so the house fuse which is the earth protector is driping off.
Your oven definiatly need to be open and check by and electrician.
Good luck
Jul 26, 2010 | Miele H147MB Convection/Microwave Oven
No power. but it is pluged in and checked breaker
Try plugging a lamp intothe same socket and see if it comes on if it does the fuse in the micro wave has blown but there are up to 5 fuses on some models so I need a model and serial number to help you fix the problem.
Sep 28, 2009 | Sharp Microwave Ovens
Galanz Microwave problem
its more likely to be a fuse from the transformer to the cap or the diode.
Sep 14, 2009 | Microwave Ovens
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
I have Problem with my microwave
it may be just a fuse , but if the fuse inside the microwave blows again then there is something else wrong and it would need to be tested to find the problem and fix it
so the fuse inside needs to be check and or replaced and if the microwave powers and works ok after replacing the fuse , then the other fuse was just bad
Jan 11, 2009 | Emerson MW8108P Microwave Oven
Maytag MMV4205 Microwave Oven Logo
535 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
