Question about Sony BDP-BX1 Blu-Ray Player
My Sony Blu Ray player BDP BX1 won't play any disc,blu ray or regular DVD ? Did the online software update.
  • Sony Master
  • 1,587 Answers
I assume you tried the software update after the unit failed. If it quit working because of the firmware update, you may have received a corrupted file. In that case, try downloading a new copy on a different computer or to different media, and repeat the update.
If (assuming hardware problems and not bad firmware) it cannot play any optical disk, not even audio or photo CDs, I would suspect the laser in the optical drive has gone bad. Replacement is not a lot of work, but the part is probably about $50. I think it's likely this is the same part used in the Sony Playstation 3, which had some problems with lasers dying too soon when it first came out.
Here's a way to check: first, insert a DVD in the player. Unplug it and remove the top cover. Caution: do not tip the player with the DVD inside. CAUTION. Directly viewing the laser can cause severe damage to your vision. DO NOT put your face over the DVD drive - ever - while it is plugged in. Observe it from the front, a little off to one side. Before plugging in, check the ceiling overhead and make sure there are no mirror-finish or glassy reflecting objects above the player. The DVD must be in first for safety reasons; it covers the laser. The rest is additional precaution.
Now, plug in and turn on the player. In normal operation, the laser comes on, and the lens moves up and down to focus on the disk. You may see a blue glow in the center of the disk (especially in a dark room). If the laser is working and the laser/lens assembly is able to obtain a focus, the disk will start spinning. If the disk does not spin, the laser/lens assembly is the first suspect. It is also possible that the spindle motor drive is bad, but given the history of PS3 Blu-Ray drives...
If there is no movement of the lens assembly, check the power supply. If it is good, there is (by elimination) another problem with the lens assembly (controller problems, to the best of my knowledge, are rare). Because it has very tight assembly tolerances, the lens assembly is usually replaced as a unit rather than repaired in the field.
Posted on Oct 17, 2010
Why won't it stream or play disk?
Call Kurtis: Why Your Samsung Blu-ray Player May Not Play ...
sacramento.cbslocal.com/.../call-kurtis-why-your-samsung-blu-ray...
KOVRSep 26, 2013 - Blu-ray players aren't the same as DVD players. ... disc compatibility issues arise and firmware updates for our Blu-ray players are ... My BD-C6500 is apparently one of those old blu rays that won't play blu rays. ... If you are viewing netflix streaming thru your samsung bluray then YES it definitely can. Its not ...
play mp4 files on a blu-ray player - MP4 - Streaming Video ...
www.tomsguide.com/answers/id.../play-mp4-files-blu-ray-player.html
Jan 9, 2014 - I see a lot of Bluray players will play mp4 files. ... If it won't do it via the USB port, will it do it if the mp4 files are on a DVD? ... player has a menu, items likeDisc Tray, Netflix (I use this menu choice to watch streaming Netflix), ...
Sony BDP-S590 3D Blu-ray Disc Player with Wi-Fi (Black)
www.amazon.com/...Blu-ray-Player.../B006U1YUZE
Amazon.com, Inc.Sony BDPS790 4K Upscaling 3D Wi-Fi Blu-ray Disc Player. 4.0 out of 5 stars 334 · Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player .... With the Sony BDP-S590, you can wirelessly stream music throughout the home to .... at internet.sony.tv as in the past some Sony products won't connect to certain services ...
Amazon.com: Sony BDP-S5100 3D Blu-ray Disc Player with ...
Jan 07, 2016 | Televison & Video
NEED TO EJECT MY DVD USING THE TIME WARNER UNIVERSAL CONTROL. WHICH BUTTON IS IT?
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
Nov 23, 2013 | Sony BDP-S300 Blu-Ray Disc Player
My Sony Blu-ray BDP-S300 will not read blu-ray disc.
You need to update your software. go to network update but you have to do it via your network it worked for me. Hope this helps
Sep 24, 2012 | Sony BDP-S300 Blu-Ray Disc Player
My sony bdp bx1 is updated and still can not play any universal and some Columbia and Fox discs
Will it play standard DVD discs, if yes there is a problem with the laser pickup assembly, blu-ray disc require greater precision and speed when playing these discs because of the higher resolution.
Apr 11, 2012 | Sony BDP-BX1 Blu-Ray Player
Certain movie will not play /
You need to update the firmware. go to www.sonystyle.com then to support, type in your model #' and look for downloads. Complete instructions are given to the user as to the installation process. If you have difficulty, Contact Sony Support directly and they will send you the firmware updates on disc at N/C. Hope this helps
Jun 14, 2011 | Sony BDP-BX1 Blu-Ray Player
Can't get some blu ray discs to play on player. Discs are formatted for player.
Update your fireware.
Pavtube Blu-ray Ripper is the best Blu-ray ripping software, is capable of ripping both Blu-ray discs and standard DVDs to your required HD or SD media formats.
Feb 19, 2011 | Sony BDP-S300 Blu-Ray Disc Player
We are having problems with our BRD player BDP s300 playing BRD. It will play regular DVD just fine.
In most cases, the issue might be with the Java contents on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service.
Jan 09, 2011 | Sony BDP-S300 Blu-Ray Disc Player
I turn on blu ray player and it goes to the regular sonybluray screen and as soon as disc starts to load, screen goes dark and no picure but I can see its playing by the counter
Try updating your player's firmware. You can download the firmware file from sony's website. The blu-ray players require many updates because the blu-ray discs have format changes and special numbers that the player needs recorded into the firmware so the newer movies will play. Here is a link to the download page for the BDP-S300 player. http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300&LOC=3
You will need to select the download for your operating system. Then you will need to burn the files onto a cd-r disc using the "burn image" option of your burning software. Once the disc has been made you can load it into your blu-ray player and then update the firmware. once updated it should bring your player back up and running again. These players require periodic updates. The newer players that can hook up to the internet update automatically when hooked up to the internet.
Nov 19, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Crank 2 will not play in Sony S350
The software updates for your Sony BDP-S350 can be found at their website here. You will need to download the file, burn it to a disc and then load the disc into your player to upgrade its software to play your new blu-ray movie.
I hope that helps.
Oct 03, 2009 | Sony BDP-S300 Blu-Ray Disc Player
I lost the remote of my Sony BDP-BX1, and I cannot Play the movie
right. well as far as i can see its as simple as getting a new remote. the problem with these is, no, they dont have many manual options. so unfortunately you will have to replace the remote
May 05, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Sony BDP-BX1 Blu-Ray Player Logo
628 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
