Question about Polaroid IDF-1030 (826219006783) Digital Picture Frame
I think I deleted the slideshow software from my Dalton PF A702 picture frame.....can I get it to re-install, or can I apply any free software to the memory card to allow picture viewing
4 Suggested Answers
SOURCE: my camera says card error.
may be not your memory card, but your slot memory card the trouble. If have enough tool and brave, you can disassemble the camera. Find the bent iron in your memory card slot. Straight it again. If you don't find the bent iron, maybe the .... Clean it...I ever solve this problem in the canon ixus camera. maybe sometime if i find this problem again I will post it in my blog.Thnks
Posted on Aug 22, 2009
jerryg50
  • 1667 Answers
SOURCE: i have a i533 5.0 megapixel digital camera.I took
You caused a card conflict, or have corruption on the card.
Try this:
Remove the battery from the camera.
Remove the memory card, and re-insert.
Install the battery back in the camera.
Turn on the camera.
In the setup menu or the equivalent for your camera, select the card options. Indicate for it to re-format, or re-initialize the memory card.
If the above does not work, you should call the support line for your camera.
Jerry G.
Posted on Sep 26, 2009
  • 11967 Answers
SOURCE: Digital frame won't read memory cards
Did you format the card before trying to use it?
Posted on Dec 31, 2009
How to start slideshow after selecting the pictures
When you power on the picture frame, a slideshow will automatically display the photos on your memory. (If you have not inserted a memory card yet, the slideshow will display the photos pre-loaded into the internal memory.)
To restart the slideshow, press
ENTER again, or press the Slide Show button on the remote control.
May 05, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
I have a smartparts picture frame.SP113mw Just loaded new pictures and first pic comes up and freezes, tried re-connecting to computer nothing. Can't use any of the buttons its locked up and can't...
The first (most obvious?) solution is to discard/destroy/disable/discombobulate the SP113MW. For my Mother-in-Law, I just deleted some of her images from built-in flash.
The SP113MW has a 128 mB flash drive that is accessible by USB, per previous suggestions. HOWEVER, the probable reason that your frame freezes on startup is that you have more than 744 images in the "Smartparts Pictures" folder on the built-in flash memory.
The SP113MW has a maximum limit of 744 images for a slideshow rotation, regardless of how much space is on the drive (that includes Built-in flash, USB, SD, or any of the drives). The default drive on startup is the built-in flash, so you may just have to delete some images to get under the 744 limit. FORGET the manufacturer's claim of "2000 images" (because it is technically correct); you can store 2000, but you'll never play a slideshow of 2000 (nor any slideshow if you have that many images). Reduce to 744 (all jpg's) and all will be well.
The other irritating thing about the SP113MW is that it does not allow the slideshow to include all drives: just one drive at a time, and that drive cannot have more than 744 images on it (or the slideshow freezes). That is why your comment about "trash" may not be a bad idea. However, mine Mother-in-Law's still works, so I accepted the limit, and it still sits on her shelf.
Sep 22, 2011 | SmartParts SPX8 Digital Picture Frame
How to un-link a picture so it can be deleted?
To unlink an album, you must go to your My Frames Page and select Albums linked. Then un-check the album and click apply. You could also go into the album where it is and delete the one picture. If you need additional help, contact CEIVA Customer Care at their U.S based toll free line at 1-877-692-3482.
Nov 12, 2010 | Ceiva Digital Picture Frame
How do you add pictures to the photo fram:
Use PhotoFiltre free photo editor program to edit your pictures.
You may download it from the below link.
http://www.4shared.com/file/gqHN4jSz/pf-setup-en.html
1. Photos should be in .jpeg format.
2. It is better to scale your photos with the above editor to 800x600 pix.
3. Prepare your pictures in a PC using PhotoFiltre. Scale all the pictures.
4. Transfer your pictures from PC to a USB Flash Disk (Memory Bar)
5. Plug USB Flash Disk to your Photo Frame.
6. Probably your photo frame will ask to transfer your pictures from flash disk to internal memory. Accept this and by pressing enter/OK/Set (Any button that changes from one product to another.)
I think it helps.
Jun 15, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
I can't get my DP702 digital frame to save my pictures from my camera. Can you tell me how to do it ... ty
The DP702 frame only takes 14 pictures saved to the slideshow file. Install a memory card/device, then plug in the usb cable, electronic store carry it for 7 or 8 dollars. It's too bad, it doesn't come with the frame. Choose the photo you want saved, and press the save button on the remote to save the photo to the slideshow, if you press it again while you're on the same frame, I think it will delete that photo. I hope that helps.
Dec 26, 2009 | Coby DP-772 Digital Picture Frame
How to play PPT on Pandigital Electronic frame?
You cannot play a PowerPoint presentation files on the frame. However, if you add still images (JPG) and music (MP3). The frame can play it's own slideshow.
Oct 13, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Delete pictures
i think to unlock or unwriteprotect it to enable to format or delete a file....
Sep 01, 2009 | Coby DP-772 Digital Picture Frame
How can I see a Microsoft Power Point slide show, size 3.30MB ?
Unless your picture frame supports Power point files you can't load it straight on to it, but you could try this.
  1. Open the powerpoint file in MS Powerpoint (or download the free powerpoint viewer)
  2. Use the Print Screen button (also marked PrtSc) to copy the screen to the clipboard
  3. Paste into a picture program (such as MS Paint, free with Windows)
  4. Save the files as a JPEG
  5. Load these onto the picture frame
Hope this helps
Jan 20, 2009 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Polaroid IDF-1030 (826219006783) Digital Picture Frame Logo
Top Polaroid Photography Experts
Joseph Coppeto
Joseph Coppeto
Duke Mcadams
Duke Mcadams
Level 1 Expert
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
