How do i gain access to the door lock switch on my Kenmore model 11044932200?
    President:
  • 1,430 Answers
You need to remove the wire ring that holds the seal to the front panel. Peal the seal back and then you can reach your hand in there. Remove the screws pull switch assembly out and unplug wire connectors. Here is a link that should help Door switch replacement
Posted on Oct 16, 2010
How to open lid to check lid switch
What is the make and model number?
Mar 12, 2011 | Washing Machines
The door remains locked
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. The replacement procedure is here.
Some
Whirlpool-made Front Loading such as the Kenmore Elite use another type of door lock and switch assembly but still with the release tab and can be accessed through the washer top. Remove the screws attaching the top panel to the rear of the machine then pull the panel rearward and off the cabinet. Pull the release tab until a click is heard then open the door.
Dec 24, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore super capacity 3.5 won't do the finishing spin but other wise works ,i heard it could be the door lock & switch assembly how do you change it?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Apr 06, 2010 | Kenmore Washing Machines
I believe I need to replace the door switch for my dryer. I would like to know where I can order a switch and how to put it in. I have an older model Kenmore Elite. Thank you. Dave
Hi Dave, Welcome to FixYa. I am Kelly
This manual will help you gain access to your door switch:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Pages 14, 15 and 19.
As for your replacement part, your going to need your model number that looks like this (example) 110.XXXXXXXX then go to either of these two sites and order it on line:
http://www.appliancepartspros.com
http://www.repairclinic.com
Mar 07, 2010 | Dryers
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
You'll need to manually unlock it.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore Washing Machines
How do I acess the control panel
Open the door and remove the top screws connected to the console. Close the door (not locked) and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Mar 06, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 45986 door lock
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Jan 25, 2009 | Kenmore 43142 Front Load Washer
Kenmore Elite HE3t Model#11044932200
How long is long? I have to hold the button down for about 5 seconds and I think that is to keep from accidentally turning the machine on . If it is longer than 5 seconds then maybe something IS wrong.
Sep 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
