Question about BOSS AUDIO SYSTEMS CW3500D Car Amp
Hi i got a boss audio cw3500d,i have a problem with protection led,when i power up amp everyting fine,but after about 30 min amp come off then after few sec come on,when is off protection led on.Thank you
    Sergeant:
    Champion:
  • 253 Answers
Speakers can not handle the load so the coil in the speakers heat up and shut off your amp.
Posted on Mar 31, 2015
    Sergeant:
    Champion:
  • 387 Answers
Hi
The protection led comes because the Amps internal part on the mainbaord burned or over heated
ecrdn@yahoo.com
Jack
Posted on Oct 19, 2010
  • dougbenham Feb 25, 2011
    ya well how can i fix it mines doin same thing
Protective mood
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Hopefully its not toast. .A thumbs up would be greatly appreciated if this answer is helpful to you. protective-mood-zb4bomd1rt4qms0dqd12kkt2-2-0.jpg
Jan 16, 2014 | Car Audio & Video
Power amplifier kenwood, power led blinks, no sound
There will be noaudio coming out , if the protection circuits is
sensing a fault or overload , just to protect your precious speaker
from further damage ( or the amp itself ).
These needs servicing.
Aug 13, 2012 | Kenwood Audio Players & Recorders
Why does my sub and amp go into protected mode when i turn my headlights on
Hi.
Devices go in protect mode when a fault condition is detected. These include insufficien voltage, excessive load, shorts and contact, overheating.
In your case the problem is usually excessive power draw. A contact in wiring can also cause the problem, but this is far less common.
Use a capacitor fix the excessive power draw from the amp and sub.
See:Capacitors - BOSS AUDIO SYSTEMS
Regards.
Ginko.
Jul 01, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
My boss amp is on protection mode and it wont work its a 3500 watt chaos idk what is wrong with it
Likely one of the power amps has failed component(s) and does not achieve electrical balance which then goes to protect mode to prevent damaging your speakers.
You will need to have it serviced.
Dec 25, 2009 | BOSS AUDIO SYSTEMS Music
Red status Light
If the protection LED is lit, the amp is in protect mode and probably has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Trubleshooting
Let me know if you have any other questions.
Nov 07, 2008 | Boss AUDIO RIP-596 2-Channel Ripper Series...
Low amp output
Make sure the BOSS isn't in "Protected" mode (Red led lit) and connect the speakers properly (check the connections if they are in "bridged" mode).
Also, make sure you set the cross-over, bass boost setting, bass volume control and the bridge mode according to the speakers you are connecting. Check the input level too.
The BOSS amplifiers are of very poor quality and it can be easily broken. Maybe yours is broken.
Feb 15, 2008 | Jl Audio E2150 Car Audio Amplifier
Amps
It sounds like the output transistors have failed. Disconnect all of the speakers from the amp and power it up. If it still goes into protection, an output has almost certainly failed.
To repair it yourself, you'd have to find the defective one, purchase the replacement parts and replace the parts in the circuit board.
This type of damage is often caused by driving an ohm load lower than that recommended by the manufacturer.
Oct 12, 2007 | Sony XM-460GTX Car Audio Amplifier
BOSS AUDIO SYSTEMS CW3500D Car Amp Logo
261 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
