Question about Samsung CLP 315 Laser Printer
I have a Samsung CLP-310N. I have a print quality problem, which is described in the user manual as character void. In the middle of characters, there is no toner or it is blotchy. Images are also blotchy. There are no stripes, and I was told by Samsung that this problem is not caused by the imaging unit. I have tried a couple different types of paper, and some are better than others, but they all have this problem to some extent. The problem happens on black and all colours. Any ideas?
    Master:
    Sergeant:
  • 381 Answers
Ahve you cleaned the prineter heads?
get damp cloth wipe the relevant visiable bits
also check if the paper is not damp
Posted on Oct 16, 2010
  • 1 more comment
  • miles_mckinn Oct 16, 2010
    The paper isn't damp, other than normal humidity in the air.
    What do you mean by the print heads? Do you mean the edge of the toner cartridge - the roller where the toner comes out?
  • Ikhlaq Hussain Oct 16, 2010
    where the toner sits in this case... but u will need a damp cloth to do this... and be gentle
    I gave it a wipe inside, and picked up post of the loose toner. The problem is still the same. I am really not sure what else to try. Thanks for your tips.
CLP-310N is printing blank pages
Open the front cage, an eject the Tambor Case, you will find a small case that contain the poudre o laser ink, clean it than replace it
Good Luck
Apr 01, 2011 | Samsung CLP-310N All-In-One Laser Printer
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
My Samsung color laser printer CLP-310N prints a half of a page then stops with the paper still in the printer.
I have the same issue - it is def the driver as deleting all samsung drivers and then getting the printer to produce a self test print works perfectly!
Dec 25, 2010 | Samsung Office Equipment & Supplies
I have a Samsung CLP-300 Laser Printer. I am getting two vertical voids in the black printed pages. I've installed a new black toner cartridge, but that did not help. How can I eliminate the vertical...
If your printer prints like this:
slamfix_13.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Dec 22, 2010 | Samsung CLP 300 Laser Printer
Printing faintly on left side of page
Is it possible to print a test page? Delete the print driver and reboot. Reinstrall print driver. Look in the manual to print a character set page usually you hold a button and turn on the the power. If that doesn't work put the file on a disk and go to your local copy center.
Nov 10, 2010 | Samsung CLP-315W Laser Color Printer
Have just connected Samsung CLP-310n (ethernet to router) and installed the software. However, when I want to print using the CLP-310n driver, it always prints to file rather than the printer. Any...
First make sure the printer is the default printer. If you have office or some other program you can get the print to file setup as the default printer. Just open printer right click and change if required to make it the default. If you don't have a printer hooked up the default is either fax or print to file. So you need to make sure the network printer clp300 is set as the default.
Next go into printer properties and check to see if the driver itself is set to print to file.
Also check your program to make sure it isn't set to print to file. That may be under setup, options, or page setup depending on the program. Usually if you set it to use the default system printer you are ok.
I'd assume its just the first thing ie default printer not set. Sometimes network printers aren't recognized as they should so you have to tell it whos boss ;-]
Aug 14, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-310N when printing it is very noisy
most probably the printer fuser unit is giving you the noise...
Jun 21, 2010 | Samsung Office Equipment & Supplies
I would like to setup my printer to print in black by default, even color images ; Samsung CLP-310N
Right click on the printer in control panel
Click properties
Click the box PRINT IN GRAYSCALE
Click OK
Mar 16, 2010 | Samsung CLP 300 Laser Printer
Problem with printed character size on Samsung CLP 300
It sounds like your drivers are bad reinstall the printer.
Dec 18, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 315 Laser Printer Logo
574 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
