Question about Whirlpool Refrigerators
My refrigerator is slowly leaking water into the refrigerator from the freezer down the back
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling.
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
Why is my freezer leaking water into the refrigerator ?
Hey Trudy Guldin, thank you for your post!
Based off the information you have provided its sounds like there could be a potential issue within your solenoid, water valve, or water filter of your Frigidaire refrigerator. When was the last time you changed your filter? I would remove and make sure there is no damage visible on your filter. If so, you would need to replace the filter. If it is any one of the other underlying issues I would recommend having a technician come out to the home and properly repair your appliance. -Matt
Aug 27, 2014 | Frigidaire Refrigerators
How to fix water leak on GE Profile Refrigerator
I would look at the dispenser door for the ice (ice chute) I have seen this door not completely close and cause leaking the you are describing. This door is has a black seal, use a flashlight, from the inside of the freezer door, look for light on the outside of the door. I think you leak is there and replace the solenoid for the door to fix this issue. Good Luck, if you want more help please input a model number. Thanks
Aug 17, 2014 | Refrigerators
Water is leaking inside
Clogged drain plug. the plug is located in the back of the freezer. Empty the freezer out and pour VERY hot water down the drain hole slowly this will unclog the drain and will stop water from leaking inside your fridge.
Jan 02, 2010 | Whirlpool Refrigerators
Water leaking inside fridge.
If you remove the back panel of your freezer you will notice what looks like a drain - melted water will go through a drain hole that extends to your refrigerator inside a cup that slowly drains the water through a tube through the back of your refrigerator and down the drip pan. Your cup may appear fine, but maybe there is some obstruction somewhere causing the water not to drain fast enough - so what happens is that the cup will eventually overflow - try to see if you can remove this and pass a long wire down the drain tube at the back to dislodge anything blocking or partially blocking it - see if you can also clean your drain cup, eventually small derbris accumulate. At the back of your freezer panel look for any partial or complete obstruction of the drain hole and its surroundings, which might be iced up.
I myself have had this problem for months, my refrigerator would have water at the bottom accumulate and eventually under the crispers a river of water :)
Cleaning the cup and the drain tube at the back of the fridge and the drain and surroundings at the back of the freezer panel should fix this problem. Sounds like your drain at the freezer level is plugged up and water is backing up and leaking from elsewhere !
Sep 25, 2009 | Frigidaire PLHT219TC Top Freezer...
Water leaking from bottom
Hi, during the defrost cycle the water runs down a pipe to a pan by the compresser where it evaporates back in the house. Ck to see if water is prevented from reaching this pan
Aug 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Oct 29, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
