Question about Crosley Dryers
My dryer thuds as it spins. it heats and is turning. what is wrong?
  • Crosley Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Oct 16, 2010
Kenmore gas dryer serial number 97220100 spinning and turns on but not drying or heating up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101/.>?'
Aug 12, 2011 | Kenmore Dryers
Dryer will turn on and count down but will not start to spin or heat up, model med6600tqo
heatman101
Apr 28, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
Jan 03, 2011 | Roper RGX4634KQ Gas Dryer
Dryer spins, but no heat. vent is not plugged. when dryer spins only cold air from the vent
heatman101
Dec 11, 2010 | Dryers
Maytag electric dryer turns on, spins, but no heat. Purchased new 8/2005
heatman101
Sep 23, 2010 | Dryers
The dryer turns on and spins, but it won't heat up anymore
heatman101
Jun 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Will spin but no heat
heatman101
May 13, 2010 | Kenmore 400 6942 Dryer
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
The dryer heats fine but when the drum turns it makes a loud clinking sound like a bearing is going.
IT COULD ALSO BE YOUR BELT OR YOUR DRIVE BELT PULLY SOME DRYERS USE A GLIDER TO ROLL ON OR THAT THE DRUM SITS ON WHITCH IS JUST A PIECE OF LEATHER OR PLASTIC ECT. THAT THE DRUM SITS ON WHILE IT SPINS
Mar 08, 2009 | Dryers
Dryers Logo
65 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
