Need hook up instruction - Computers & Internet
    Problem Solver:
  • 6 Answers
1.To hook up a router plug the internet cable into the port marked internet. If there is no port marked internet then plug it into whichever port is separated from the other bank of ports. If the ports are contiguous then plug it into the port marked 1.
2.Plug your other Ethernet cables into the remaining ports.
3. Follow the manufacturers instructions to install any necessary drivers. If you cant do that for some reason then you should go to http://compnetworking.about.com/od/workingwithipaddresses/f/getrouteripaddr.htm to figure out your routers IP address, then go to that address using your internet browser and follow whatever instructions/basic setup wizard it has.
Posted on Oct 16, 2010
Singer 2263 instruction manual does not show where to lubricate or how to adjust the hook which keep jamming
First make sure that the needle is fully up. Then you need to open the hinged front cover and unscrew the needle plate screws. Remove the bobbin. Brush out any lint now. Remove the bobbin case. Then snap the hook retaining arms outwards. Remove the hook cover and hook. Put no more than 2 drops of sewing machine oil on the the case (center right hand side). Then turn the hand wheel until the hook race is in the left position. Replace the hook and then the hook cover. Snap the hook retaining arms back into position. Replace the bobbin case and bobbin. Then replace the stitch plate.
Test the machine on a piece of waste fabric. If the hook keeps jamming, take the machine in for maintenance. The parts that may need to be replaced are the race or the shuttle hook. However without seeing the unit I do not know if there is not another problem. Some parts for the 2263 are available here: http://www.sewingpartsonline.com/singer-2263-sewing-machine-parts.aspx .
Singer has a second manual available with the oiling instructions for the 2263 here: http://www.singerco.com/uploads/download/1213_oiling-2263.pdf . See the diagrams on this page for where things line up. The rest of the instruction manual is also online here: http://www.singerco.com/uploads/download/1180_2263%28eng_spa_fre%29.pdf .
I hope this helps.
Oct 08, 2011 | Singer 2263 Mechanical Sewing Machine
I need assembly instructions for disney princess
Use the hardware that comes with the Disney Princess canopy package to install the main canopy hook in your ceiling. Center the steel ceiling hook above the center of the twin bed and screw it into the ceiling by hand or with pliers. 2 Follow the included instructions and insert the four poles into the sleeves of the canopy. The two longer poles will run lengthwise above the bed, while the two shorter pieces will run widthwise above the bed. 3 Attach the canopy to the ceiling hook by slipping the plastic ring of the canopy onto the hook. The four polyester sides of the canopy should now hang over the twin bed. 4 Use the customer support form through the Exxel Outdoors website if you have questions regarding your Disney Princess canopy.
  • Jul 10, 2010 | Princess International Nursery Crib Bed...
    Where do I find the instructions for the hook up for the water line for the ice machine??? Thanks
    down load the instructions from whirlpool / all hooks are general . / you need a ice maker water kit / home depot will have this with instructions also most appliance parts carry the whirlpoo kit . ( its very simple . . ) . mm
    Jul 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
    Need instructions
    most amps are self explanatory just look at the outside edges where the wires go into the amp and they are usually printed positive remote negative and so on with the speakers
    Apr 05, 2009 | Car Audio & Video
    Kirby Ultimate G series model 293001 instructions
    I have my original instruction booklet that has approximately 8 pages of instructions on how to hook up the shampooer....just not sure how to post it here if i scan it for you. If you can tell me how to do that I would be happy to scan for you.
    Mar 31, 2009 | Kirby Ultimate G Bagged Upright Vacuum
    Need instructions for Captain Hooks Pirate Ship
    go to service.mattel.com and click on instruction manuals and you should be able to print them out
    Jan 01, 2009 | Toy Island Captain Hook's Big Pirate Ship
    Instructions for hooking up a new monitor
    if you attach correctly all the connections then nothing to worry about. if you just follow all the instructions carefully and correctly then set back and relax... okay...
    Dec 14, 2008 | HP W2007 LCD Monitor
    SPEAKERS
    Go to your tv manufacturer's website to get instructions/manual.
    Warning: make sure your TV has an audio OUT or OUTPUT, or you will not be able to hook stereo directly to TV and get it to work.
    Jan 13, 2008 | RCA TH1101 MP3 Player
    Computers & Internet Logo
    David Payne
    David Payne
