Question about Tivoli Model CD CD Player
I have a Tivoli CD player thar only will play obout 3/4 of any CD
I have a Tivoli Music System radio/CD player. When it is moved to another room and plugged in at the new location, it won't run! The screen lights up a little, but has to sit for 30-40 minutes bef
The Tivoli Music System must be left without power for a minute (60 seconds or more) anytime it is unplugged, before being plugged in again. If you observe this little rule when changing rooms, it should turn on and be usable immediately (after ensuring it has been at least a minute since it was last connected to power.)
Nov 18, 2012 | Tivoli Digital AM/FM/CD Hi-Fi Music System...
CD player won't play MPEG-1 layer 3
If it is just a standard cd player it will only play audio cds.
Mar 10, 2012 | Audio Players & Recorders
When I insert a disc into the Tivoli CD player - it immediately shows a message "no disc" and rejects the CD
Ah yes, very annoying problem. I am still searching for the solution and trying not to have nervous break down in the meantime.
May 06, 2010 | Tivoli Model CD CD Player
Tivoli Audio Music System: CD wont eject
We've had the Tivoli Music System for 3 years. A CD became stuck in the player when I pressed the EJECT button before turning the player on. We tried turning it off and back on, unplugging it for a minute, removing the batteries and unplugging, etc. Nothing worked. I finally turned the player upside down in my lap, then turned on the CD player, and it said LOADING! Progress!!! I turned it right-side up and hit EJECT, and it worked like new. The CD loading mechanism had become bound up and simply needed a different "attitude" adjustment. Don't give up too early in attempting to fix these players on your own.
Feb 17, 2010 | Tivoli Audio® Music System Shelf System
Have to wiggle ipod connection for it to work
More than likely a dirt connection. Unplug the unit, get a mini connector and spray a electric cleaning solution on the connector and exercise(plug/unplug about 10 times) the port. This should free up any dirt that might be in there. If this doesn't work at all, then it's a loose connection inside. Either bad connector or loose solder on board.
Oct 28, 2009 | Tivoli AUDIO Model CDBLK CD Player CD...
My Tivoli CD player is ejecting cd's. Those it does accept play badly and jump. I am trying to insert a CD cleaner, but this gets ejected as well!!! Help!!
If it is under warranty simpyl return it to get it repaired.
It seems either there is something stuck inside what makes it think there is already a CD inside or your eject button is stuck internally. If not under warranty and you're a bit handy, try to open it and see if there is anything inside the CD area that makes it eject CD's or if one of the small wires connected to your eject button is loose or if there is a shortcut inside.
Aug 08, 2008 | Audio Players & Recorders
Uninstall
remove the frame around it, find something thin and flat enough to fit the slots thar located arounf the inside of the face this will releae the entire unit from the sleve
Mar 25, 2008 | Kenwood KDC-MP232 CD Player
Tivoli Model CD CD Player Logo
63 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
