Question about Viking Professional Series VCBB36 Bottom Freezer Refrigerator
I need to clean the coils on the refrigerator. Are they in the back? Do I have to roll out the fridge? It is eight years old.
  • Viking Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
I have an eight year old fridgedare gallery side by side fridge.this morning its freezer is working ok but fridge side is warm.feels like no air is comming to the fridge.feels like there is some ice build...
Sounds like the evaporator is froze up. You may have a defrost problem. First I would check and see if the condensor coils on the bottom, if they are, clean them. I cant look up a wiring diagram without model and serial #'s. Do you know where the defrost timer is? hope this helps.
Oct 23, 2011 | Refrigerators
Frigidaire FRS26F5A fridge at 50 degrees
You will have a blockage in the ferfigeration system. Its not a big deal, a technician needs to regas the fridge. Make sure he installs a new drier before he pumps gas into the fridge. (When the drier is contaminated, it restricts gas flow). This is what you have with your fridge..
Sep 25, 2009 | Refrigerators
SIde by Side Kenmore -- Freezer is fine Fridge Is Warm
the freezer needs defrosting or the evaporator fan has failed and is not blowing air into the refrigerator side.
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Same problem.... almost eight years July 7, 2009
Dirty condenser (the coil under the unit or behind it). Vacuum it out. Could possibly be the thermostat going bad or the compressor. If it has an ice machine, it may be bad. Most fridges run everything through the ice machine.
Try cleaning it inside and out and make sure the inside coil is not frosted over. That could be a symptom of another problem.
Jul 08, 2009 | Maytag MSD2756GES Side by Side...
My refrigerator is almost constantly running. It stops for about 15 minutes and then turns back on. I have cleaned the coils, but this has not helped at all. Can this problem be fixed or is it time to...
Your cooling coils are completely clogged with dust and I'd check your refrigerant level. Clean first then keep an eye on it for two days then if no improvement in lowered temp call in a repairman for a refrigerant top off. $$$$ Expect over $150.00 plus!
Try an air tank with a long blow off tip to clean the dust off the coils. No simple task!
Jul 07, 2009 | Refrigerators
My freezer isn't keeping foods frozen. It's an eight year old Whirlpool. The fridge section also isn't keeping the food as cold as it used two. I have turned both sections to max for coldness. I have...
You can have the freon checked or recharged, or you might have to take the motor apart and blow it out with air or pressure wash it. The compressor may be going bad most of the time it's cheaper to replace deep freeze instead.
May 01, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
GE side by side
check your main board (located on the back wall of the fridge). pull board out and check back of it, usually one relay legs burns out.
Oct 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
Viking Professional Series VCBB36 Bottom Freezer Refrigerator Logo
274 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Jim Y
Jim Y
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
