Question about Soehnle 63697 Comfort F5 Digital Scale With Remote Transmitter, Silver/Black
SIGNAL error message. Radio transmitter dead?
Iphone 4 lost signal,when try to make a call
Sounds like a problem with the radio transmitter in the phone. You will need it repaired or replaced I fear.
Apr 05, 2014 | Apple iPhone 3G
Tip
How to add an iPod Input into a Stock Radio?
<p>You can add an iPod to a stock radio in your car, even if the plant does not have an auxiliary input or iPod input using a specific number of iPod car accessories. One such accessory is a cassette adapter that plugs into your iPod as a headset, but ends on a cassette tape to your stock cassette radio. However, not all cars have cassette players, thus more accessible to the FM transmitter. <br /> <p><br /> <p>1. Connect your iPod to an FM transmitter, if you connect headphones to the iPod. <br /> <p><br /> <p>2. Connect the FM transmitter to your cigarette lighter to power and then to the transmitter. <br /> <p><br /> <p>3. Press up and down on the transmitter to the FM transmitter to change, you will pass the signal to your radio. Choose a station that is not a radio station on it so you do not interrupt the signal. <br /> <p><br /> <p>4. Set your stock radio to the channel you selected on your transmitter and then play the songs on your iPod. You will see the songs on your iPod through the radio station you selected. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
Will remote key entry work if battery is dead
Remote key entry will not work if the key battery is dead. the key "transmitter" sends out a radio wave continuously and the receiver which is located in the vehicle recognizes that signal, unlocking the vehicle. If the battery is dead there is always another manual option to gain access to the vehicle.
Oct 11, 2012 | Mopar Chrysler Town & Country 2001-2008...
I have a 2004 GMC Envoy with 6 cyl engine. Both remote keyless entry went dead at same time and now I can't unlock the back hatch door. I had to release it manually but the sensor keeps locking it back....
Take it an have it check at a qualified repair shop for DTC'S - diagnostic trouble codes . Could have problem with the liftgate/endgate module. Don't try guessing to find a repair .
The keyless entry system has the following main components:
• The transmitters
• The endgate module (EGM) (XUV only)
• The liftgate module (LGM) (Except XUV)
When you press a button on a transmitter, the transmitter sends a signal to the liftgate module. The module interprets the signal and activates the requested function via a class 2 message over the serial data line.
Do you know what class 2 serial data communication network is ?
You need a scan tool to program the remotes .
Program All Key Fobs
To complete this programming operation, all keyless entry transmitters associated with the vehicle must be available for programming. Once placed into program mode, all previously programmed transmitters will be erased from memory upon the receipt of the programming signal from the first transmitter.
Close the lift gate.
Ignition ON, access the scan tool Liftgate Module Setup menu and select Program All Key Fobs.
Follow the the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
As each transmitter is successfully programmed, the scan tool will show how many transmitters have been placed into memory.
When all transmitters are programmed, exit the program mode by selecting "Stop" on the scan tool. The vehicle will not respond to the transmitters until the program mode is exited.
Operate the transmitter functions in order to verify correct system operation.
012 GM Class II Communications
Jul 25, 2017 | GMC Envoy Cars & Trucks
When, I am walking around with either a guitar plugged in or a lavaliere microphone. I continue to get pops and static surging sounds. Is there a way to fix this.
Hello
Although it has 2 antennae the AT201 is a single channel transmitter and receiver. As you move the transmitter about in relation to the receiver you are finding 'dead spots' in the room where the signal is reduced or even drops out completely. You can reduce the impact of this somewhat by doing the following things.
  1. Make sure there is a clear line of sight between transmitter and receiver.
  2. Move transmitter and receiver closer together
  3. Do not locate the receiver near large pieces of metal or near other electrical equipment, particularly things that have strong magnetic fields like transformers (including amplifier power-supplies) CD or DVD players, hearing loop amplifiers and loop cables.
  4. Turn off mobile phones and any other radio operated equipment that is not needed
  5. Turn the trim control on the transmitter to the maximum output that you can without causing distortion. The stronger the original signal from the transmitter the lower the related noise will appear to be (called signal - noise ratio)
  6. Turn the squelch control on the receiver up a bit to suppress noise - however doing so will reduce the strength of the output signal a bit so don't over do it.
  7. Use good quality screened cable between the receiver and your amplifier. Unfortunately the AT201 only has an un-balanced mono jack socket so this cable will be more prone to pick up radio interference than a twin core plus screen (balanced) cable.
  8. Make sure that your signal cable does not run parallel to, and close to, any mains electricity cables. If the signal cable needs to cross any mains cables it should do so at 90 degrees and the cables router well away from each other.
However the only real solution to this sort of problem is to use a full duplex (2 channel) transmitter / receiver system which will automatically switch to whichever channel is carrying the stronger signal. Typically these cost about 70% more than single channel units but they often use balanced cable outputs (stereo jack or xlr) which further reduce the propensity for noise due to interference.
Feb 02, 2011 | Audio Technica (ATW-T201-T2) Microphone
Station to get signal from FM transmitter
I put the transmitter closer to  the antenna and it periodically worked. So, I don't there is a specific station.
May 18, 2009 | Audio Players & Recorders
"NOTONE" Error Message.
I had this problem once and it was a malfunction transmitter circuit board. Had to call Sony service to replace the board.
Try another transmitter to help confirm the receiver is functional.
Mar 22, 2009 | Sony (UWP-S1) Professional Microphone
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Soehnle 63697 Comfort F5 Digital Scale With Remote Transmitter, Silver/Black Logo
73 people viewed this question
Top Soehnle Health & Beauty Experts
Tom Chichester
Greg P
Greg P
jerry sheehan
jerry sheehan
Level 1 Expert
Are you a Soehnle Health and Beauty Expert? Answer questions, earn points and help others
