Question about Lexmark X2500 All-In-One Printer
Help!! i am trying to scann photo's to put them on my computer but when i push the scann button it reads printer has stopped working microsoft is trying to find a solution but nothing is being solved?
Peggie, I recently had the same problem with my printer. your best bet is to install the drivers from the cd that came with your printer. Then go to lexmark to grab the drivers from there web site. install them. A window will pop up and ask you if you want to update driver or make another copy. select make antoher copy and let it install. when done turn on lexmark imaging studio and it will give you a choice of running the original program or the copy, run the copy and there you go no more APP4RE.exe has stopped working. ENJOY!!!!!
Posted on Jul 25, 2008
I want to Scan a page on Lexmark X6150. Please guide me how to set the Options and Select buttons. I pressed the start button after pressing the scan button. It does do anything.
Find the "menu" button on your printers keypad and push it. Use the up and down areas on the printers keypad to advance from choice to choice. Find the option that says something similar to "scan settings" . Push the "ok" button or the "enter" button on your printers keypad to open this option. Continue scrolling with the up and down arrows and using the ok or enter keys on your printer and locate the "scan to" choices. Set up your software choice for scanning text documents and pictures. Most people want to open and edit text documents in software like "Microsoft Office" in your computer. Choose a photo editing software installed in your computer to send pictures scanned on your printer to. When these settings are set and saved, turn on both the computer and printer and try scanning from printer to computer again to check and see if the problem is solved. If you experience any other issues, pleas clarify what they are and I will try and help you solve this right now before I leave for work.
Sep 27, 2010 | Lexmark X6150 All-In-One InkJet Printer
My canon Pixma IP1500 start blinking 10 times alternationg orange and green, then repeats. I even reset waste ink counter, but no luck. Please help me out. Thanks.
How To Reset Waste Ink Canon Pixma MP450
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 29, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
MP800R: Error code:201 - Printer can print but not Scan!MP800R: I can use the printer for printing al right, but when I try to scann I get a message that I should close the printer, and read the manual...
Error code:201 occurs due to USB conflict or software not running properly....
Solution#1: Take out the scanner from USB port... shut down the computer.... then restart the computer and plugin your USB plug in anyother USB port(not the ealier one).. Then check if that works.
Solution#2: Click on Start > Click on Run > Type Services.msc press ok.... on the services window check for "Still Image Service" right click on it and select properties .. then click on stop then start(if it is already stoped then click on start).... also make sure the Startup Type: Automatic....
Jul 17, 2009 | Canon Office Equipment & Supplies
Please rate!!
Jul 17, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
I am having problems scanning from my mfc=420cn. I don't know how to scann to file on windows vista/ or microsoft word. It only lets scann to images
Try setting up the scanner in the scanners and camera control panel.... more than likely you are just hitting the scan button on the printer and it is using the defaults on the printer's installed software and is automatically sending it to your images folder. Maybe some clarification on exactly what you want to do?
If you have office, open microsoft document imaging and acquire the file that way ( acquire scan, and then cut and paste into word)
Mar 08, 2009 | Brother MFC 420CN All-In-One InkJet...
I am trying to scan a photo. I put the photo face down on the scanner of my HP Photosmart C3150 All-in-One then push the button for start scan/reprints and nothing happens. Can you help me?
I had purchased a new computer that ran on Windows Vista. I was able to go onto the HP support and found out that the scan button would not work because the printer was purchased before Windows Vista operating system came out even though the printer and copier part worked fine. HP support offered two solutions and the one that worked for me was to:
Click Windows Icon
Choose Programs
Accessories
Paint
File
From Scanner or Camera
Scan
Nov 03, 2008 | Office Equipment & Supplies
Scan Photos
u put ur picture on glass of scanner . and give command to scanne after scanning computer will ask in which format u like to save ur file
Jun 03, 2008 | Brother MFC 7420 All-In-One Laser Printer
How do I scann a document/picture and where does it go once I scan
Usually any scanned document etc will go to a folder in documents & settings so have a look there, another way is to scan and save it as a special name, or simply remeber the default name, and then do a search for that file and when you find it, THATs where they go :)
Usually when ya scan it should ask ya where to save?
Feb 07, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
71 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
