Question about Hitachi PJTX100 Multimedia Projector
Fans runs but a clicking sound is heard.sometimes the bulb comes on and sometimes the projector turns off
    Problem Solver:
  • 6 Answers
I'm not entirely sure what you mean by "the bulb comes on" but i can answer your other questions.
1. A clicking sound made by the fans is usually caused by a cable obstructing the fans, you should first try using some computer duster (canned air) to clear the blockage, if that doesn't work you can take it to someone who fixes projectors or you can open the case yourself and move the cables out of the way.
2. The projector turning off on its own could be caused by overheating. This can happen if you leave it turned on for too long. I would not attempt to correct this your self, as i don't have enough information to be sure about this, too fix this you should ask the manufacturer to replace it or take it to a professional.
Posted on Oct 16, 2010
Just clicks want come on
there is a few things that can cause that 1 the bulb blew 2 the cooling fan quit or 3 the hitemp sensor for the bulb is bad sometimes its cheaper to replace a rear projector tv then to repair a bulb on some models can run $600.00
Aug 23, 2013 | Toshiba 50A62 50" Rear Projection...
The status light is on our NEC MT850 and the bulb looks fine. What other problems could it be?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 19, 2012 | NEC MT850, MT1050, MT1055, MT1056...
Viewsonic PJ500 bulb does not come on
Hi.
Look at the base of the bulb at the filament in the center of the bulb, if buldging change he bulb first. If the porblem continues then have the units Ballast or Sometimes called the lamp driver check and replace if defective. The cheapest way is the check the voltage at the lamp connections in the housing for At least 280 volts, while turning on the unit you will need a voltage meter to do this.
Mar 03, 2010 | ViewSonic PJ500 Multimedia Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Sharp XR-10X projector. Makes a loud whirring noise when trying to turn on. Bulb starts to turn on then doesn't. It's not the fans because I opened up the projector, disconnected the fans and it still...
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 14, 2010 | Sharp XR-10X Multimedia Projector
I have an Optoma EP745 projector. I heard a 'pop'
check all the fans, if still working. if the problem occur get assist to the nearest technician im sure your lamp balasst was deffective.
Oct 22, 2009 | Optoma EP738 Multimedia Projector
Epson ELP 3000 clicking noise and all lights flashing
Have a nice day!
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
I can't get the light to come on.
Sounds like your black screen shutter is not opening allowing light to pass through. Try it with the carousel and slides installed. Run a few passes.
Mar 05, 2007 | Vivitar V5000AF Slide Projector
Hitachi PJTX100 Multimedia Projector Logo
81 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
