Hi. We have a Hoover vhd sensor dry (vh w 644 d) and every time we try to do some washing it comes up with the E02 error. What do we do wrong?
  • 1294 Answers
SOURCE: Hoover VHD Washing machine
Surely it is the wall socket.
Posted on Mar 19, 2008
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: hoover nextra sensor washer dryer, 6+4kg 1300, has
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
SOURCE: I have a Hoover vhd sensor Dry Washer Dryer and
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Posted on Oct 03, 2010
SOURCE: I have a hoover washing
EO2 on my washing machiner
Posted on Feb 01, 2011
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
I have a Hoover Vision HD 9 kg washing machine, type VHD 916Z. I does not spin when there are clothes in the machine, it just starts the spin then "gives up" after 0.5 to 1 second. When there are no...
Double check the waste pump on the inbound side, which could be the cause of a wrong feedback to the pressure sensor switch. The filter can be clean, but the collector from the basket to the pump can be obstructed.
Jan 26, 2015 | Hoover Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
I HAVE HOOVER VH W 644 D what does E 11 mean
Hi, you've posted your query in 'computer motherboards', try reposting in 'domestic appliances'
Nov 29, 2012 | Computers & Internet
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
Hi Have got a hoover optima about 18 months old. Has got an E02 message in the middle of a cycle because the water board have turned the water off without telling anyone. Can't open the door or get...
'E02' for your Hoover Optima states 'fill time-out' which is not surprising considering that the water board turned the water off!
I hope by now that the water is back on and so is your washer ;-0)
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 27, 2011 | Hoover Washing Machines
I have a Hoover vhd sensor Dry Washer Dryer and its come up with error E11. Can you help ?
Jun 23, 2010 | Washing Machines
Washing Machines Logo
366 people viewed this question
Top Washing Machines Experts
