Question about Sony STR-V555ES Receiver
Hi I have a sony v555es, center and surround channels work occasionally, connections & speakers are perfect (I've tested both) and so are receiver settings
  • 15 Answers
SOURCE: Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Posted on May 11, 2007
  • 5 Answers
SOURCE: Sony STR-DE845 center channel cut out, receiver clicks
I have fixed 3 shorts on my de845. 2 have been caused by cracked solder joints. they were speaker cutout problems...yours most likely is the center channel relay on the main board. take the thing apart. you need to get to the back of the main board and re-flo those solder joints. get your geeky pc buddy and do it together(buy him a sixer). its really not that hard...just a bunch of screws. disconnect everything from the main board including the front plate. be careful with the ribbon cable...mine is hurting at this point. not meant to be removed so many times. put it in straight. my leads bent, but was able to straighten them. there are 5 relays together, one for each channel. they are white cubes and prb a little smaller than the tip of your finger. its the 4 leads on each of these that you want to take a soldering iron to . i'm not sure which ones the center channel so do them all in that area. it may be hard for you to tell which leads they are so just go overboard and at least get everything in the vacinity. i did all component leads because who's to say another's not ready to go bad. you've gone this far. touch the heated up tip to all the leads at the very end of the barb. you can reflow the solder without actually touching it. the metal lead will get hot enough. hold it until the solder liquifies, then let it cool. do this on a flat surface. my other fix once was a re-seating at the speaker switch a,b,a+b on the front plate. there are 2 boards plugged together there. i bent the leads slightly so they seated in more tightly. if your left or right front goes out, sometimes thats an easy fix...try b if you're using a, or the opposite. don't forget the speaker cables. if you're using both zones then you prb already figured out you need to re-flo! test and cross your fingers. good luck.
Posted on Jul 27, 2007
SOURCE: Right surround channel not working in some modes
I had the same problem with the right channel.    It turned out to be a broken wire inside the receiver; it can be found connecting from the main PCB to the card for the 5.1 board.    After repairing the broken wire, it has worked fine.
The harness connects the 5.1 low level signals to the board which are then redistributed to the amplifier section.     It is a bundle of wires in gray casing and with red, black and white wires (with shielding).
Find the offending wire, repair or replace and it should be fixed.
Hope this helps
Posted on Oct 27, 2007
balls
Posted on Dec 20, 2007
SOURCE: No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Posted on Feb 10, 2009
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
Onkyo TX-DS696 receiver center channel not working
Can you say explicitly that the Center Channel speaker is defined as something other than NONE?
And how does dialog sound? If it sounds ok you're routing it to the front speakers. This is from the manual...
"For ideal Surround effects, all speakers should be installed. If a
center speaker or subwoofer is not connected, the sound from the unused channel is properly distributed to the connected speakers in order to produce the best Surround sound possible."
Apr 10, 2010 | Audio Players & Recorders
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Sony center speaker and rear speakers don't work all the time
try using another speaker for the center channel and the left speaker, also watch your ohm load, most of the want a 4 ohm load. try to narrow it down to see if it is the speaker or the amp.
Mar 13, 2009 | Sony Audio Players & Recorders
Audio Video Receiver Problems
It sounds like the center channel isn't plugged into the correct speaker output. Unhook the speakers and reattach them while paying VERY close attention to which jacks you're putting them in. Report back with results.
Sep 11, 2007 | Sony STR-V555ES Receiver
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
Sony STR-V555ES Receiver Logo
46 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
