Question about Haier HSB03 Compact Refrigerator
IS THERE A RESET BUTTON OR CIRCUIT BREAKER FOR THE COMPRESSOR ON A HAIER COMPACT REFRIGERATOR.
5 Suggested Answers
  • 400 Answers
SOURCE: haier compact refrigerator freezin up. Thermostat
There should be a clip on the back of the evaporator plate with a bit of foil which normally covers the stat wire end which is the sensor.
Posted on Mar 05, 2009
  • 63 Answers
SOURCE: Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Posted on Mar 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Kenmore fridge compressor not going on - reset circuit breaker?
Look at item 4 on this picture for location of the defrost timer. You will need to rotate it with a flat head screwdriver and you should hear a click to see if your compressor starts. On the first picture above about 0.5 inch from the top from the 12 o'clock position is the dial that you will need to rotate It should be mounted horzintally in the top of your food section. The dial could be white or black. It has 2 tabs on it and can only be rotated in the direction that the tabs would be engaged by a flat head screwdriver. Turning it backwards will result in having to replace the defrost timer straight away. So again rotate this dial and see if your compressor starts.
http://images.google.com/imgres?imgurl=http://www.appliancepartspros.com/sect/b/u/1/bu16zh5hjj.gif&imgrefurl=http://www.applianceblog.com/mainforums/whirlpool/14104-whirlpool-freezer-evaporator-freezin-over.html&usg=__XxMLJp3a6BBih2eOJKB6x3mtNqk=&h=939&w=680&sz=45&hl=en&start=6&um=1&tbnid=qKT0RbtaUM62dM:&tbnh=148&tbnw=107&prev=/images%3Fq%3DDefrost%2Btimer%2BDial%26hl%3Den%26safe%3Doff%26rls%3Dcom.microsoft:en-ph%26sa%3DN%26um%3D1
If it starts then you have either a bad defrost timer or 60 deg F thermostat in the freezer section coils.
If it does not start then you can have a bad compressor relay, run capacitor or the compressor itself has failed. If the compressor is hot and you hear a hum from the compressor for about 30- 45 seconds it could be any one of the 3 above.
I would be willing to go out on a limb here and say you most likely have a defrost circuit problem.
There is a remote possibility that you had a one time instance of the defrost timer sticking but on an older unit If it stuck once it will most likely stick again in the future.
Posted on Jan 16, 2010
  • 66 Answers
SOURCE: My Haier compact refrigerator won't turn on
A new thermostat is required. When you turned it down you probably broke the contact and will not re-connect. Be careful installing the new one the fine tube contains gas which is temperature sensitive. do kink or break it.
Posted on Apr 18, 2010
Will not turn on when i plug in
Check breaker first, then wiring. Is this older than7-8 years. If so, get anew one . Labor and compressor will cost more than its worth.
Jan 28, 2013 | Haier America 1.7 cu ft Compact...
My Compact refrigerator completely does not work when I plug in the power . ( I try to looking for part # P6R8MCOR0401 it marked on starter )
If you know the power outlet is good but the compressor does not come on, then it could be either the contactor relay or the start capacitor or the compressor itself.
The problem is that most compact refrigerators are more expensive to repair than to replace, so if it is the contactor or relay you can change them but if it is the compressor it is cheaper to replace the unit.
Aug 04, 2011 | Haier HSP03WNA Compact Refrigerator
My Haier compact refrigerator, Model # AES27, stopped running. I unplugged it and then plugged it back in and only hear a humming sound for like 10 seconds and then nothing.
These are noted for bad controller boards. It is located under the back cover. Look under the cover and see if the control circuit board is blackened or smells burned. You can get parts at this link:
http://www.repairclinic.com/Haier-Parts?gclid=CMajgvvFpqYCFYdi2godeBsFmA
Jan 06, 2011 | Haier HSB03 Compact Refrigerator
My Haier HRT02WNC Compact Refrigerator is blowing warm air and will not blow cold on any setting
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 22, 2010 | Haier HRT02WNC Compact Refrigerator
I have a Haier compact refrigerator (Model: HSP03WNWAWN-01, Serial Number: A205673063 - I defrost it and know it will not get cold. It comes on but will not get cold. I tried plugging in in for 24 hours...
Unplug the unit then turn the thermostat all the way on then all the way off, then slowly move from off to fully on position do you notice a spring popping sound at a certain point? Yes No? if yes turn it all the way off and wait ten minutes then plug back on, notice if the compressor comes on or not. If it does then turn the thermostat to half way on does it cool now? if yes you have the problem solved, if not you have an issue with the defrost circuit and you need tools to test it, if you have an ohm meter let me know and I will help you further. Thanks for using fix-ya
Jun 05, 2010 | Haier HSB03 Compact Refrigerator
My small haier fridge just makes a clicking sound but does not get cold. Is there a reset switch or fuse?
the clicking niose is the compressor relay . and needs to be replaced . this may not get the comp going as it may be stuck or motor windings burnt . . then replacement of compressor in needed . mm /hope this hepled .
Jan 16, 2010 | Haier HSB03 Compact Refrigerator
Haier HSB03 does not cool, just clicks, when it kicks on.....
Most of the times the problem is the compressor relay that get stuck , try replacing it (no more than $30) , but if the compressor still clicks and won't start probably is burned out.
Oct 15, 2009 | Haier HSB03 Compact Refrigerator
Light is on and thats it
Check to see if the compressor is hot. be carefull it can get really hot if its malfunctioning. If it is not hot then maybe the breaker switch on it does'nt reset anymore. Try replacing that.
Jun 28, 2009 | Haier HSL04WNBSS Compact Refrigerator
Haier aficionado model AES44BPG compressor wont stay on
I had the same problem. Mine turned out to be the PTC starter. Checked the compressor coil resistance and it ws fine. Replaced the PTC starter with Item #: 1268268 from Repairclinc.com and it started right up. The PTC starter was an exact replacement.
Hope this helps some else trying to solve this problem. To bad Haier doesn't offer this part!!
May 01, 2009 | Haier (B000194UBA) Compact Refrigerator
Haier HSB03 Compact Refrigerator Logo
233 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
