Question about Memorex MT2271 27" TV
Memorex mts tv 27"
Is there a remote for this tv that I can get rather than a universal remote? thanks, cindy
  • lyn-hanna Oct 14, 2008
    lost the remote for the same model and would like a new remote as the universal one does not operate the menu for watching movies... Would like another as well...
    Please respond asap
5 Suggested Answers
SOURCE: Memorex MT2024 programing
Same deal here. I forund A web site with this phone number 954-660-7100. I will try it tomorrow and let you know if I get the right code
Posted on Feb 01, 2008
SOURCE: universal remote programming
Use 2 remotes!
Posted on Jul 29, 2008
SOURCE: need memorex mt2274 tv code for comcast multi-control remote
I've had the problem this morning. Memorex codes are 10154, 10463, 10150, 10178, 10016, 10179, 10877, 11570, 11911, &11920. These are for the remote that is for the smaller digital box. I tried them all, and 11570 works for my model - the power shuts off, but the comcast remote will not turn the power back on. Volume works ok.
Jim
Posted on Jan 05, 2009
  • 8 Answers
SOURCE: 27" Memorex MT2274 won't play blu ray player
Chances are, you are trying to view on the station set for your VCR or other peripheral equipment, such as channel 3 or channel 4. You need to be sure that you have your TV set for on one of the two auxillary stations, instead, which will show up on your TV as "Aux 1" or "Aux 2."
Posted on Mar 15, 2009
  • 8 Answers
SOURCE: REMOTE CONTROL LOST
You can buy a clone from a company like Remotes.com. Their prices are surprisingly low on this unit. (Sometimes this is not always so!) You can find it here:
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=12370820789860&smodel=MT2274&brand_pn=MEMOREX_MT2274
If you do not see your exact remote here, chances are, from the codes you listed for your set, you actually have an MT2274A. If so, then try here, instead:
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=12370820789860&smodel=MT2274A&brand_pn=MEMOREX_MT2274A
(If you do have the MT2274 and not the MT2274A, and would prefer an original remote, I, personally, have one I would be glad to sell you. Just let me know.)
Hope this helps in some small way!
Linda T.
Lost remote need code for universal remote
since most of the disney TVs are manufactured by memorex company ..... from your universal remote control's manual check the codes for memorex brand & try it .... if you don't have manual for your universal remote then from this link http://www.remotecentral.com/features/remotes.htm identify your universal remote & in that check codes for memorex brand & try it .... while searching answer for your question i have found that many people have same problem that is code for universal remote ..... but they never got right answer ......... & also neither same original remote control nor equivalent remote control is available (spare ) ...... so in case if you don't get right code then consider selling of this TV & buying new tv ...........
Oct 28, 2011 | Disney Lightning McQueen TV
I need the code for the TV so I can program it into my universal remote control. The TV is an older model 26". Thank You
The only way to know the code is either from the manual that came with the universal remote or from the manual from the T.V. Check on the documentation from the remote and make sure the code is on there, otherwise the remote won't work with that T.V.
Jun 01, 2011 | Memorex MT2271 27" TV
I need the code for a GE Universal remote Control for a memorex TV
Hello, you will find the complete code list in the ge' website: jascoproducts.com / you will need the model number for your remote.
Oct 20, 2010 | Memorex MT2271 27" TV
A friend gave me a Sanyo MTS TV..has no remote, programed a universal remote still won't work. can't scan for channel,it is stuck on video 2,HELP
Try website 1-800-Remotes Factory orginal.To buy an exact orginal remote.Have all the funsctions,usally the universal remote don't.
Feb 25, 2010 | Sanyo DS27510 27" TV
Need memorex mt2274 tv code for comcast multi-control remote
Jim
Oct 14, 2008 | Memorex MT2274 27" TV
Need remote code number.
What is the name brand of your tv?
Sep 04, 2008 | Televison & Video
Tv remote needed
The most inexpensive solution, is to buy a universal remote. I own a One-for-All universal remote (model URC-4220) which works with Memorex TVs. I bought it at Walmart for less than 10 dollars.
If you want to pay a little more money, here are a few websites to visit: REMOTES.COM 1-800-REMOTES
MRREMOTECONTROLS.COM 1-800-221-1471
You can find a few more websites by typing in:
MEMOREX TV REMOTES into the Google searchbox.
Hope these suggestions help you out. Please take a moment to rate the info I have provided, but using the rating system below. Thanks.
Jul 11, 2008 | Memorex MT1194 19" TV
Universal Remote
I downloaded the tv's manual, mine is a model:1350, but it says at the bottom of the manual it is from Memorex, so I found the codes in my remote(a OneforAll brand code 0463) and it worked. So if you haven't solved your issue, do a memorex code. Now that I look at the date you probably have. Oh well.
May 26, 2008 | Disney DT1350-P 13" TV
Sanyo MTS TV
Hello
Most universal remotes should have a TV/Video button. Look carefully on the remote. Or get another brand remote.
Also depending on your Sanyo model there may be a TV/Video switch on the front of the set. Look for a possible small cover along the bottom.
Feb 26, 2008 | Televison & Video
Memorex MT2271 27" TV Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
