Question about Peerless Industries Peerless& Single Handle Tub & Shower Faucet
Shower drips - seems to be increasing - Peerless Industries Peerless& Single Handle Tub & Shower Faucet
  • 7,482 Answers
Need to replace your internal seals inside the shower valves.
Go to Home Depot, Lowes,etc. and make sure you take your model number and maker of your shower and they can get you the parts to repair the valves to stop your leak.
If you do not repair it soon, the water leaking by will cut your metal seat and it will never stop dripping, you will have to replace the valve and it is a MAJOR job.
This is a free answer, Please rate me
Posted on Oct 16, 2010
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Sep 25, 2009 | Delta & Single Handle Shower Faucet
Shower head dripping cant turn shower knob off
Mixer valve needs repair. special tools required.
Aug 21, 2009 | Home
Shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
May 28, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
Leaky posi temp shower valve
coming from the uk it sounds that when you mention it leaks at night its a possibility thats when the water pressure increases & the valve starts to drip?
i know its not a solution but it may help you understand why its dripping at night.
Also the seals might be damaged in which case thats why its dripping check them for damage. make sure when you put the new cartridge in that you put some silicone grease around the seals as this helps the insertion & helps protect the seals from damage.
Kindly
Richie
Dec 15, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Peerless Industries Peerless& Single Handle Tub & Shower Faucet  Logo
650 people viewed this question
Top Peerless Industries Home Experts
Donni Steen
Joe Lamb
Joe Lamb
john h
Are you a Peerless Industries Home Expert? Answer questions, earn points and help others
