Question about Mitsubishi WS-65807 65" Rear Projection Television
Screen is black, only menu items come up. When they do they do not converge, i.e. each color is projected alone and out of sinc.. Sound is working. Lamps are lit and working.
  • 4 more comments
  • leinberg Oct 16, 2010
    manufacture date October 2000
    what is the picture wheel?
    The is a set of six adjustments behind the front panel. I see where they can be adjusted but it does not put the images together or cause the video to return
    This is a projection tv, how do I check the color wheel?
    Please explain what is the color wheel, where is it located, what does it look like?
    I will contact you in 24 hours.
    President:
  • 1,961 Answers
You need to check the convergeance IC.The IC is mounted on the mainboard It has a big heatsink and labelled STK ####.Before replacing the convergeance IC try to resolder first the pins of the IC both the 2 IC a cold solder on the pins can cause the problem....after soldering and nothing happens then that is the time to replace the IC ...After replacing the IC check for open fico resistors near the IC this resistors serve as fuse whenever the IC is bad....be sure to unplug the TV before servicing to avoid shock!good luck let me hear if you have further questions..please do rate my help!
Posted on Oct 17, 2010
  • 712 Answers
How old is the TV?
Posted on Oct 16, 2010
  • 3 more comments
  • Sebin Punnacheril
    Sebin Punnacheril Oct 16, 2010
    I think it is the picture wheel. Give it a check.
  • Sebin Punnacheril
    It is an internal device in LCD/Plasma TV's similar to picture tubes in older versions. Sometimes, it may go faulty due to many reasons, resulting in misconfiguration of colors or sometimes even entire loss of video.
  • Sebin Punnacheril
    If the picture wheel is faulty, simple adjustments won't solve the issue.
  • Sebin Punnacheril
    If it's a projection TV, it might be the picture tube getting magnetized. UNPLUG the TV for over 24 hours. In SOME cases, the tube may demagnetize all by itself. Also be careful not to place any other magnetic or electrical substances (which can cause a magnetic field near it), during these 24 hours.
  • Sebin Punnacheril
    Please look the comment below. If it's a projection TV, it would be a magnetized picture tube that is causing the problem, not the color wheel.
HI i have an RCA HD52W59 and the picture looks 3D, I can use the manual convergence but when tv is shut off and turned back on it goes back to the 3D look and the auto convergence does not work - the...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 02, 2011 | RCA HD52W59 HDTV Projection Television
Wont power up. Made a pop sound and hasn't worked since. Light on front blinks red when you push any button on the remote so its not completely dead but no picture or sound.
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Samsung HC-P4752W 47" Rear Projection...
Red,blue,green lines in screen....sound is fine. How can I converge the colors back?
Go to Menu then Setup Look for Convergence, If you do not see Convergence in the menu, then you have a blowed Fuse on the Deflection board.
Dec 23, 2010 | RCA R52WH73 Projection Television
We have a Zenith 56 inch rear projection tv. Model num# R56W36. The picture did the 3-D thing on us when I hit auto-convergence button. We ordered new parts from TVRepairKits.com. Replaced parts and now TV...
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
9e1b49a.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 22, 2010 | Zenith R57W46 57" Rear Projection...
I have a magnavox 52 inch tv the picture got a mirred look to it then went black but can still hear te sound can you tell me what's wrong
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Oct 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
KP-43t75 no picture black screen, Menu comes up bowed
Ur convergence it dead.Buy a convergence kit,replaced what in that kit.Know how to solders right?Buy a convergence kit in these websites Tv repair World.com,Tv rpair Kits.
Feb 04, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 23, 2008 | Sony KP-53XBR200 53" Rear Projection...
Rca d52w19 convergence hell
Did you replace the convergence board or the convergence power supply board? usually one color will be a problem with the convergence board and more than one color means the convergence power supply is the problem. Ebay isnt a good place for boards as you never know if the board is good. You can get the convergence or the convergence power supply boards at the following link along with free shipping and tech support.
http://servicemanuals.vstore.ca/
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
Rca rear projection hdtv lost color convergence
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
Blue color lamp cannot converge
GO TO THE CONVERGENCE MENU (MENU 2 3 5 9) AND CHECK THE ADJUSTMENT SETTINGS FOR CONVERGENCE. IF ALL ITEMS ARE SET AT "127". THE EEPROM SETTINGS ARE AT DEFAULT.
Nov 30, 2007 | Mitsubishi VS-55601 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
