Question about Pioneer Premier DEH-P480MP CD Player
I had a problem with the security system in my car now my stereo just flashes and beeps at me with an ocasional A popping up
    Scholar:
  • 127 Answers
Need to get a digital volt meter and check for powers and grounds to see if your geting enough power to power it up or your ground is bad
caraudioquestion@gmail.com
for more questions
Posted on Oct 16, 2010
Security light flashes yellow then red. Please Help!
For some odd reason Chevy sometimes has there stereos connected to the security system. Check the fuse to make sure it didn't blow. You probably have vats security which is the worst thing ever made. I had that on my 02 firebird and had nothing but vats issues constantly.
Apr 01, 2015 | 2002 Chevrolet Chevrolet Tahoe
Changed car battery and the dual car stereo won't work now. reset the stereo and the security light is flashing and the stereo still won't work?
Your solution depends on the brand and model number of your stereo system I take it your stereo system is Ruth is included in a anti-theft device this is highly technical and manufacture specific you need to follow the instructions for installing the system initially somehow your system lost sanity. You need to unplug the fuse that goes to your stereo turn your stereo switch on and let it sit for a day then return with the users manual and go through the installation sequence that has to do with connecting power and setting default settings other than that you have to contact the manufacturer
Nov 25, 2014 | Dual Xdma6540 Car Stereo Receiver
Security system reset
You can usually reset the alarm by unlocking the car using the key in the drivers door.if that doesn't work the alarm module is usually in the drivers kick panel area and unpluging it will usually disarm.all this if its a factory system. If aftermarket just look for the alarm brain and unplug it till you can get it to a stereo shop.
Feb 13, 2014 | 1995 Mitsubishi Galant
Car wont start
I would put the old stereo back in, many cars and likely this one need the factory system for the security system to function correctly. You can also call this company for help, there may be a kit. www.crutchfield.com
Jul 02, 2012 | 2012 Mazda MAZDA5
I have a 98 Nissan altima gxe and my alarm won't honk when I lock the car but the lights go off when I lock it and Wen I take the alarm off no honk or lights go off Wat can I do
holdboth the lock and unlosk buttons on your remote simultaneously for about five seconds until the lights flash and horn chirps.that should do it.if not i believe these models used a separate horn for security system.possibly fuse for this horn is bad or the horn itself is bad.to see if this horn works lower drivers window.stand outside vehicle and lock doors with remote.wait about a minute and reach in window and MANUALLY unlock and open door(do not use power door lock button)this should cause the system to activate...horn should beep and headlamps should flash.if horn beeps try my first suggestion.if it doesnt beep and just the head lamps flash check fuses and horn for security system.
Feb 21, 2011 | 1998 Nissan Altima
2001 z71engine shut down. low fuel light no gear indicator showing in dash no spark no fuel pressure. has full tank, engine cranks, fuel gauge is reading empty, has been missing ocasionally. put scanner on...
It sounds like a shorted class2 data line to me. Is the scanner giving you U-codes? (U1000, U1042, etc.) If you are getting U-codes that is your problem.
Jan 05, 2011 | 2001 Chevrolet Silverado 1500
My toyota Lucida diesel engine runs good but ocasionally gives a pop, pop, pop,sound with white then black smoke and looses power .
Probably the oil seal for the valves on the cylinder head are not good,oil is passing through then comes in the cylinder chamber,when it burn the engine oil it makes that white smoke.
Feb 21, 2010 | 1992 Toyota Previa
Where is fuse in Alpine CDE 9842 Car Reciever?
Had to take the vehicle back in to the repair shop. Good thing. Found smaller fuses blown and wires crimped behind stereo in dashboard. Told this could have been the original reason for main fuse failing. Works like a charm now, auto antanna raises, seatbelt light beeps and security system lights up. Stereo also works.
Sep 14, 2008 | Alpine Car Audio & Video
Sony microvault 2 gb
my laptop does not read the usb stick, when i insert it, a pop up says usb device not recognized, and has malfunctioned. I am having this problem after using this usb device in a car stereo system. please advise i need to recover my data from the device. please help me in this issue.
Apr 10, 2008 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Pioneer Premier DEH-P480MP CD Player Logo
26 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
