My magnavox model 20mf605t/17 tv/monitor will not turn on. I plugged it in and pressed the power button and nothing happened. Any help would be appreciated!
  • 191 Answers
SOURCE: Tv doesnot power on
two options _bad backlight inverter or the main board ;eed to be change.
Posted on Nov 02, 2008
thekleppinge
  • 5 Answers
SOURCE: My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Posted on Dec 06, 2008
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
SOURCE: magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Posted on Mar 27, 2009
  • 6 Answers
SOURCE: No power to TV
vizio does not sell their service manuals to the public.
Posted on Jul 15, 2009
What connection do I need to use Magnavox 17" Model 17MD255V/17]TV/DVD as a monitor on a computer? Error message says "No PC Signal" Monitor cord is on. Power cord is on. What's missing? thx
You need to let the Magnavox know what signal it should be displaying. Look for a "Source" button on the remote or menu and choose PC or whichever slot you are hooked up, say HDMI.
Mar 29, 2017 | Power Computers & Internet
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
Tv has white lines across top of screen. philips magnavox 20MF605T/17
The tv has a vertical problem caused by one to three bad capacitors and possibly the ic, that will exhibit the symptoms you are describing.
Feb 19, 2011 | Philips Televison & Video
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
Magnavox 15mf605t/17 15'' LCD HDTV won't turn on
Have similar TV. If it is set to the PC source, it goes into standby when there is no signal, like a regular monitor. Even though the monitor is in standby, you can still press the Source button to change to, say, HD input, and will use the familiar on/off action when pressing Power on the remote.
A little weird, but I've gotten very used to it.
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Need manual
does your tv have a round button in the front of the tv push it then see if it turns on.
Nov 09, 2008 | Televison & Video
I have Direct tv and pused the wrong button on the remote to my Magnavox 20MF605T/17 TV. Now I can't get the picture back. How do I fix? Thanks, Curt
Depending on your TV and receiver there should be a button on the remote that says Format push that button a few times and see if the picture comes back.
Nov 05, 2008 | Televison & Video
I have a Magnavox 51" Projector TV. Model 51MP392H/17
Hello bullmuscle,
This is a power supply problem, I would suspect the HV power supply because the primary and secondary supplies anymore are tied to the HV power supply. This type of repair requires certain pieces of equipment, to test voltages, look at signals, and to if need be test for shorts in inductors (Switching PS transformer and Flyback transformer). I would not recommend that you try to fix this yourself, The cost for this type of problem is not that expensive and can be done in one evening, if the parts are available. You may be fortunate and it could be just a blown fuse, in the HV or LV power supply circuit
I hope this helps,
Thank you,
Shuttle83
Jul 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Problem with Magnavox 15MF605T/17B
Hi SgtHoagie and anyone else:
I ran across this problem too, at 1:30 this morning. At that time I had to get out of bed and try to figure out what the hell happened. It seems that my flat panel TV somehow got switched over to the computer monitor mode. When this happens, the light will turn an amber color. On the bottom of your flat panel you'll see some very small buttons, marked "MENU," "CH" "VOL" and "SOURCE." You'll want to click on the "Source" button and that will switch your flat panel back to the TV mode. Your flat panel TV can also be also used as computer monitor.
Feb 14, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
Electro Med Services...
