Question about Motorola Mobility H500 Wireless Headset
Headset won't get recognized or connect...
Have the Motorola H500 headset and have been trying to connect it with my new enV2 but it won't recognize it or connect no matter what I do. It picked up a SHG-U700 (googled it and it's a Samung...which I don't have). My phone had a "Discovery Mode" you can set up where other devices can find you for 3min and I'm supposing that's how I found the SHG-U700. Why in the heck can't I find my own device! Help!!
  • 2 more comments
  • bjkmwk Jun 11, 2008
    With mine, it finds it, finally pairs it, but won't connect - says "Device is out of range or powered off." which it isn't. It was working last week, but now can't get it to work. Help!!
  • cherryteresa Jun 24, 2008
    I have the same problem, but with my Jabra BT2040. It will rarely ever work. Most of the time it says "Device out of range" or to make sure it is turned on and discoverable, which it is! I never had a problem with this earpiece when I had a Razr. I don't know what the issue is but it's very frustrating.
  • Anonymous Dec 01, 2008
    I ended up contacting Jabra about it and they were helpful. I got it to work again but only very temporarily and the same problem happened. I didn't have a problem with the Jabra headset until I got the LG env2 so I'm thinking it's the phone. There are issues with that phone and even other name brands have the same problem. Maybe an LG bluetooth headset would work with it. But who wants to spend the money for a new one just to gamble? I wish LG would make some kind of a download to fix this bug.
  • DeeDee85 Dec 02, 2008
    I am trying 2 connecet my H500 headset 2 my t mobile wing and it keeps telling me that it can not be found and i change the setting on my phone and everything so what do i do
    Genius:
  • 1,224 Answers
When your in device seek blue tooth mode at its start up to seek is on
now on your bluetooth your using
make sure completly off first
then when device is in seek hold the bluetooth headset power down till your device finds the signal it will tell you in 30 to 40 that its found it
if requires pin it is 0000 or 1234 or 12345 this after everything found
thats it all you had to do
Posted on Jun 08, 2008
I had the same problem. I also had trouble connecting to a friend's phone via Bluetooth. So, I took it to Verizon and tried a Bluetooth device there. same problem. So, I handed it over to the technicians and got a new phone. It syncs up with everything.
Posted on Nov 24, 2008
I am having the same problem - the above advice did not help - anyone else have an answer??
Posted on Aug 04, 2008
HOW TO CHANGE BATTERY HEADSET H500
Why do you think you need to replace the battery? A common sign that your Motorola Bluetooth headset needs a new battery is when you repeatedly hear five quick high tones in successive, one-minute intervals. Another symptom of a low or dead battery is when you try to scroll to Power and your headset doesn't come on. The Motorola H500 headset has a long battery life, but the battery eventually will go bad. Unfortunately, the battery is integrated as part of the headset's circuitry and should not be replaced by its user. Motorola strongly advises against trying to change the battery. Attempting to replace the battery voids the headset's warranty. By sending the headset to Motorola for repair, you can have a new battery installed without the risk of damage to your equipment.
But you can try the following at your own risk:
Locate the battery door at the rear of the headset and open it.
Remove the old battery. Install a new battery to match the plus and minus illustrations on the battery compartment. Shut the battery door back in place.
Select "Menu" on your phone. Select "Settings."
Select "Connection," "Bluetooth Link," and "Setup."
Select "Power." Select "Change."
Select "On," and then press "Select."
Press the "Call" button and hold it down. Release it when the LED light blinks.
Oct 11, 2014 | Motorola Mobility Universal Bluetooth...
I am trying to connect my H500 to my new
Enter '0000' (four zeros) when your phone requests a passkey whilst pairing with your headset.
Hope it works for you.
Cheers! Carlos
May 17, 2010 | Motorola Mobility Universal Bluetooth...
I can't connect my EnV2 to my Jabra Bluetooth. Is there a trick?
It could as easy as updating your phone by dailing *228 with a Verizon phone, select option 2 then press ok when the update is complete. When the phone resets, turn on the bluetooth headset, a prompt on the phone should come up to enter the passkey which should be 0000
Sep 01, 2009 | Motorola Mobility H500 Wireless Headset
Motorola H500 Headset Problem
TRhe pair code for my motorola headset is 0000 (that's zero zero zero zero)
Oct 16, 2008 | Motorola Mobility H500 Headset
H500 PROBLEMS
This is a symptom of a bad headset. You need to replace the unit.
Aug 04, 2008 | Motorola Mobility H500 Wireless Headset
Constant Seeking
maybe faulty now....try a new one and see if it finds that one, if it does then you know you will have to get a new one.
Mar 14, 2008 | Motorola Mobility RAZR V3
Problems With Pairing H500 and Motorola V190
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 24, 2007 | Motorola Mobility H500 Wireless Headset
Computer won't recognize my headset
What blue tooth atenia are you using on your computer?
Oct 22, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
156 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
