Question about Precor EFX 546i Elliptical Version 4
My precor eliptical will not turn on. The outlet is active and the power is running through the power cord, but the display screen will not turn on
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: i am looking for a parts and repair manual for a
Go to National Gym Supply @ gymparts.com or call them @ 1-800-496-7278
Posted on Jul 29, 2010
My precor 517.1 elliptical does not turn on
I would start the troubleshooting process by confirming power at the wall outlet. If this checks out, follow power from the wall to the end of the cord. If you still have power at the end of the cord, check the power inlet. If you still have power on the back side of the power inlet, you may be looking at a bad control board. Repair Parts for Precor 5 17 5 17i Ellipticals Consumer SPORTSMITH net
Sep 28, 2014 | Exercise & Fitness
No power, when I turn the switch on, the power lights do not display
Look on the back for a reset button, it could be a small red button the size of pencil lead protruding slightly, push in on it. It could also be located in side a small hole the same size use a tooth pick or something none metallic to push with...
Jan 09, 2014 | Precor EFX 556 Elliptical
Removing a user I'd password from a precor 935 2005
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Dec 21, 2013 | Precor 935 Premium Series Treadmill
We unplugged our Fitline e100 eliptical and moved it and now it will not turn on when plugged in.
Plug a known good appliance into the new outlet and verify power. Then verify all connections to eliptical.
Sep 12, 2013 | Audio Players & Recorders
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
How to unlock safety code for precor 9.35 treadmill
• Set User Name
Procedure
Sep 27, 2012 | Precor 9.35 Premium Series Treadmill
Tv flickerig on precore eliptical
Dear Sir:
You must test the power supply inside of TV, if you have skill for to do oit use DVOM, otherwise you must call some service tech, or go to repair shop.
However try to tight every connector wires, for loose, breake(test the wires for continuity) or burn.
God bless you.
May 13, 2012 | Precor C956 Treadmill with Cardio Theater...
What is the password the get the precor 3.1 treadmill to work?
• Set User Name
Procedure
Jan 27, 2012 | Precor 9.31 Treadmill
I am looking for a parts and repair manual for a precor efx546 eliptical unit
Jul 27, 2010 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
219 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
