Question about Kohler Devonshire 2 handle Centerset Chrome Lavatory Faucet
I've got a double bathroom faucet (Kohler K-393-N4-CP Devonshire centerset lavatory faucet) and the handles have come loose. I can't find a screw or anything to remove or tighten them - like most faucets I've seen. Do you know how to remove and/or tighten the handle of a Kohler bathroom faucet? Tks
3 Suggested Answers
Dplumber
  • 119 Answers
SOURCE: One of the handles on my Kohler faucet does not
Removing the faucet stems and coating them( inside and out) with plumber's silicone lubricant should solve the problem. If the stem is too corroded, you may need to replace the stem.
Posted on Sep 08, 2010
heatman101
  • 43501 Answers
SOURCE: I have an old Kohler
There should be a nut there that holds everything together...remove the nut and the guts will come up and out...
I usually use a pump pliers and a rag...to make sure I don't mess things up...
If the shroud of the handle totally covers the nuts then don't worry about the rag...
heatman101
Posted on Jan 19, 2011
How to fix a locked-up hot water handle?
Hello friend,
ALL of these taps (im english !!!) faucets ? have a LIFETIME guarantee. see http://www.faucet.com/kohler-k-8201-4-polished-chrome-taboret-centerset-bathroom-faucet-includes-metal-pop-up-drain-assembly/f230779#warranty-info
'To obtain warranty service, contact Kohler Co. either through your Dealer or Plumbing Contractor or calling 1-800-4-KOHLER or by writing: Kohler Co., Attn: Customer Service Department Kohler, Wisconsin 53044 U.S.A'
Worth a try !!! even if only to find out how to get them apart !!!!
Sep 14, 2014 | Kohler K-8211-4-CB Taboret Widespread...
How do you repair a leaky centerset Kohler forte fauset
That faucet has a lifetime warranty. Call Kohler (1-800-4-Kohler) and tell them you need a new cartridge for a K-10270 faucet.
May 01, 2014 | Kohler Forte Two Handle Centerset Lavatory...
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
Handle loose. how do I tighten?
should be a very small set screw at rear base of handle
Mar 10, 2011 | Kohler Forte Two Handle Centerset Lavatory...
Leaking from handle, how does the handle come off?
There is a small set screw on the handle it may be covered with a small cover that needs to be removed to reveal the set screw.
Mar 04, 2011 | Kohler K-10270-4-BV Forte Two Handle...
One of the handles on my Kohler faucet does not turn (at all). The model is very similar to the Kohler Memoirs centerset faucet I've noticed that the other bathroom faucet (dual sinks) is beginning to be...
Sep 08, 2010 | Kohler Memoirs Centerset Lavatory Faucet...
Water leaks around the hot water handle when I turn on the water.
what valve do you have. most likely you will need to replace the cartridges
Jul 28, 2010 | Kohler Forte Two Handle Centerset Lavatory...
Dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
Mar 14, 2009 | Kohler Model 102704A: FortĀ® Centerset...
Kohler Devonshire 2 handle Centerset Chrome Lavatory Faucet Logo
263 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
