Question about Tools & Hardware - Others
Ihad to take my EasyShot Plus (PowerShot) stapler apart to get out a jammed brad out and I can't get it to work properly.I may have lost a part.Can you send me an assembly diagram or a perts list.
  • 15,935 Answers
What is the exact model # please?
Thanks!
Posted on Oct 17, 2010
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
I just bought a Black & Decker Powershot stapler Model 5700M. I am ready to use it, but I read the Warning on the side of the stapler. It said, "Warning: For safe operation, read instruction...
was going thru older questions and found yours. If you do not have a manual yet go to dewaltservicenet.com and on the left side type in model number 5700. It will allow you to download the instruction manual. In complete it is 12 pages long but you can define the pages for what language you want to print.
Apr 28, 2011 | Black & Decker 5700 Powershot Forward...
My brad nailer shoots staples without any problem but it jams on the second brad after being freed up from the previous jam. How to I rectify this problem. It is a fairly new stapler/nailer and has done...
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
Mar 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
How do you load the Brad nails into the powershot?
load nail rail in right hand side looking at base of stapler and exit point forward
May 14, 2009 | Black & Decker 5700 Powershot Forward...
See above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Feb 02, 2009 | Black & Decker 5700 Powershot Forward...
Finding stainless steel staples
Your best bet would be to look for the size staple you want on McMaster-Carr Industrial Supply. In the search box on the top left, search for staples. You will receive a page where you can find the staple you are looking for.
Another option is to use Galvanized staples. They will have a longer lifetime in rusty environments!
Good Luck!
Ben
Jan 12, 2009 | Omega Easyshot Staple Gun & Desktop...
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Directions to open and load a Black&Decker PowerShot stample/brad gun
Check the following link in which you may find a pdf manual for your product. Just click on the "link" and it will take you to the google search for your product. Hope this helps and let us know if you need further assistance.
May 30, 2008 | Black & Decker 5700 Powershot Forward...
Tools & Hardware - Others Logo
332 people viewed this question
Top Tools & Hardware - Others Experts
Bill Boyd
ray gallant
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
