Question about GE WWRE5240D Top Load Washer
GE WWRE5240D Top Load Washer If we press the switch board and start button , then the washer starts filling. If we remove our hand then it stops. What could be the problem? Please advice.
    President:
  • 2,468 Answers
Open circuit board printed trace,replace the board due to moisture
Posted on Oct 16, 2010
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
The washer has power but when you push the start button nothing happens. The machine filled then was paused and it will not drain or restart. Any help out there?
The start button actuates a small switch on the control board. Pressing the start button hard enough can cause damage to the microswitch, and/or loosen its connection to the PC board. If you rock the start button with your finger (ie circular rubbing motion), that sometimes works. Better still, open her up, find the microswitch directly under the start button actuator, a plastic plunger that makes contact with the microswitch, and press the microswitch button directly. Try jiggling the microswitch itself while pressing in the button. If it comes on, then it's a bad solder joint.
Nov 07, 2010 | GE Profile WPRE6100G Top Load Washer
Washer stops by itself, have to press start continuously
I would check the inverter on top of the motor. The flashin led light is a code the code legend is on the wiring schematics behind the control panel
May 07, 2010 | GE WBSE3120B Top Load Washer
Push button washer wont come on. has 120v going
check an see if you got the volt down to motor if this is a real old washer it might have a start relay above the motor that good be bad
Apr 24, 2010 | GE WWRE5240D Top Load Washer
Gcxrpo9odoww GE washer .. On fill up, it over flows onto floor?
Fill switch could be bad, or fill tube could be plugged making water not stop and it keeps filling. The fill tube goes from fill load selector switch to bottom of tub. Remove from top and blow it out. If this doesnt work replace water load size selector switch.
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
GE PROFILE WASHER DOESN'T CYCLE TO WASH FROM FILL
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 19, 2009 | GE Profile WPRE6100G Top Load Washer
The machine does not stop filling up.
Te pressure switch has a tube attached, try blowing out tube, sounds like it is plugged.
Jun 16, 2009 | GE WBSE2090A Top Load Washer
GE wprb8050d0ww washer
if it fills but not wash at all suspect the pressure switch its the switch where you select the water fill small med large behind that switch will be a dome looking piece with a vinyl hose connected to it try spin drain first if all that works replace the dome switch
Jun 05, 2008 | GE WPRB8050D Top Load Washer
GE WWRE5240D Top Load Washer Logo
106 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
