Question about Hampton Bay 24002 Ceiling Fan
The hampton Bay ceiling fan has stopped responding to the remote control. Prior to it stopping to work, it would not switch off from the remote, so it was switched off at the wall switch. Since then it has not worked. I checked and the unit is getting power. Any ideas?
  • alexmccann Oct 16, 2010
    battery already replaced.
    Guru:
  • 468 Answers
It might be possible the battery on the remote is weak. Try replacing the battery.
Thanks and regards,
Anil.B.R
Posted on Oct 16, 2010
  • Balakrishnan Computers (A Computer Repair Shop)
    If the remote has new batteries then I would request you check for any dust, if it is blocking the sensors on the fan as well as remote. If still it is not working, then I think it need a remote replacement as the crystal LED on the remote is not functioning.
    Thanks and regards,
    Anil.B.R
    Thanks and regards,
    Anil.B.R
Ceiling fan with remote control stopped working suddenly, ruled out battery for remote control, because I changed a new one, ruled out circuit since everything is working, I don't have a pull on the...
with Hampton Fans,, normally if the remote is good with a known good battery , and it quits working,, its the remote receiver, not the actual remote that goes bad. you can contact these guys I heard they have the part you need http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Sep 07, 2011 | Hampton Bay 24750 Huntington III Ceiling...
I have a Hampton bay fan model UC7083T It's about 2 years old and remote control stopped working. I tryed a new battery and checked the pin switches to make sure they match and Im gettig power to it. It...
mcdevito75 here, Double check your barrey install in the remote, evn new batteries could be weak, also, you may have to get to the shroud just at the ceiling, that"s the cover for the fans wireing, and see if the reciever eye for the remote is clean. Also does the remote have to be programed to operate the fan.
Jul 24, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
I Have a hampton bay ceiling fan mod. 523 342,
if you have connected power directly to the fan motor and it doesn't turn...replace the fan.  However, also check the switches on the fan as you may have bumped them.
Mar 24, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Put remote on hampton bay ceiling fan and the led light keeps blinking when turned off
I am looking for the White Westinghouse sk26h240s remote codes for a Comcast universal DVR Remote control. any ideas, please email me at renee.walton@comcast.net.
May 29, 2008 | Universal Remote Control Hampton Bay...
Hampton Bay 24002 Ceiling Fan Logo
37 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
