Question about LG Flatron L2320A 23" LCD Monitor
My monitor screen is divided by an invisible line vertical down centre. Right side is brighter than left. Monitor is 2 months old. someone at this site suggested back light problem.
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Subtle Two Toned Split Screen Color Difference.I think I hit some button by accident. Monitor is great but now I have a split screen where the left hand side of the screen has a lighter tint than the right...
Hi. I have got the same problem, and it was very easy to solve. Monitor was LG. The problem was not in the system, it was in the monitor. I just clicked the buttons on the monitor, it was on the wrong setting that divides monitor in two colors, so if it happens to you, try checking your monitor settings, mine was set to "demonstration", half was lighter than the other one, just set it to usual or user. Keep in mind the settings are on the monitor itself, not in the windows (buttons on the monitor itself) Good luck.
May 10, 2012 | LG 22" FLATRON LCD Monitor
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
Aug 22, 2009 | LG L1915S 19" LCD Monitor
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
Thin blue line
What have they told you to do? This will help us in troubleshooting. Is this still under warranty?
Aug 20, 2007 | HP f2105 21" LCD Monitor
A pink vertical line appears suddenly on the screen
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
LG Flatron L2320A 23" LCD Monitor Logo
396 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
