Question about Datamax DMX-I-4212 Label Printer
Datamax I-CLASS DMX-I-4212
Label printer users transfer ribbon for grey labels but does not automatically reset for white labels which do not use transfer ribbon ...
Please advise how to calibrate or setup the printer settings to automatically select / switch options between the transfer ribbon for grey labels and white labels (which do not use ribbon) without the printer prompting for transfer ribbon all the time ....
  • am123 Jun 03, 2008
    I require a manual for troubleshooting and problem fixing and settings for the Datamax I-CLASS DMX-14212 label printer urgently please ...
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Posted on Aug 19, 2008
Keep getting a check supply error
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
Oct 04, 2013 | Datamax DMX-I-4212 Label Printer
Do you know the part number to order the ribbon or film?
After doing a little research, I can see why you are having a hard time figuring out the correct part number to replace the ribbon.
Here's what I found as a compatible ribbon on the CDW website:
http://www.cdw.com/shop/products/default.aspx?edc=2066585&RecommendedFOREDC=320985&RecoType=AP&cm_sp=Product-_-ComplAcc-_-Datamax+Pioneer+GPR+Plus+-+print+ribbon
The Datamax website has a chart with Media and Ribbon Requirements for I-Class models on page 111 of the following online PDF:
http://www.datamaxprintingsolutions.com/corp/88224101_p.pdf
Hope this helps. You may also wish to get purchasing help from the sales agents at a company like CDW or Tiger Direct (CDW's number is (800) 800-4239
Steve G.
Jan 20, 2011 | Datamax DMX-I-4212 Label Printer
Why wont my datamax 4208 printer read the same label format as the 4212
It will read and print the label format, but you need to download and choose a different driver for the other printer. Seagull Scientific makes the drivers for Datamax, so visit their site for the most recent versions. you will need to open your label format in your software, duplicate the label format and choose the new driver for the I-4212.
Sep 10, 2010 | Datamax DMX-I-4212 Label Printer
HELLO!! MY EQUIPMENT IS DATAMAX DMX-1-4212 AND TO THE MOMENT TO STAMP THE RIBON WRINKLES AND ORDERS THE IMPRESSION WITH STRIPES
poor tension on the rollers?
try pulling the ribbon during stamping, if this corrects it then you may need a tech to come and reseat some drive gears.
Jun 10, 2010 | Datamax DMX-I-4212 Label Printer
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
Datamax I-4208 ribbon loading
Follow the arrow symbols stamped on the ribbon spool assy
Sep 24, 2009 | Datamax DMX-I-4212 Label Printer
NEED MANUAL
Try this link:
http://www.datamaxcorp.com/software/i-class/
Theres 2 programmer manuals. One is for version 10 softare, the other is for version 11 and higher.
Sep 10, 2008 | Datamax DMX-I-4212 Label Printer
Media settings for thermal labels
The size of the labels you wont have to tell. In the control panel of the printer you will have to tell it to print thermal and that will turn the film transfer roller off.
You may have to tell it the size though in the software you are using.
Aug 28, 2008 | Datamax DMX-I-4212 Label Printer
Thermal Ribbon has a wrinkle
The thermal print head is damaged. You can try to clean it with a thermal printer head cleaner. That will only help if it is just clogged up with thermal print ink.
Aug 19, 2008 | Datamax DMX-I-4212 Label Printer
Printer Ribbon has a wrinkle in it
Remove the ribbon and try to remove the crease. Check the printhead for obstructions. You may have to open up both halves of the ribbon cartridge to look for jams or obstructions.
Datamax DMX-I-4212 Label Printer Logo
718 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
