Question about Nintendo DS Lite Console
My daughters nintendo ds keeps asking for the system settings to be adjusted every time it us turned on. Once this is done it restated and asks fir them again. Please help
I have the same problem, when you have the solution, please let me know!!!
Posted on Dec 29, 2010
HOW TO USE BROWSER.KEEPS ASKING FOR SYSTEM UcPDATE
To get the latest available features as well as the most current enhancements to the Nintendo 3DS system's performance, we recommend downloading the most current System Update.
Important! Your Nintendo 3DS must be connected to the Internet to perform these steps. (How to)
What to do:
  1. Turn on your Nintendo 3DS and access the System Settings by tapping the wrench icon.
  2. Tap "Other Settings."
  3. Tap the right arrow three times to reach page "4."
  4. Tap "System Update."
  5. Tap "OK."
  6. Tap "I Accept."
  7. Tap "OK" to begin the update.
Downloading the system update will resolve the issue you are having.
May 31, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
My daughters ds lite will not load her r4 card any more,it saysthere is no DS card inserted.!!
CAREFULLY use pressurized air on the ds hopefully this will clean out any dust. Blow on the hole. Check another game to see if it works instead of the game you constantly keep trying. Ask her if the ds ever got wet, because once a DS gets wet and you've been turning it on or off it fries the motherboard inside and it's pretty much useless.
Jan 23, 2011 | Nintendo DS Lite Console
Hi there. My DS was sat in a draw for a year or so, and now when i come to turn it on, it asks me to adjust the system settings. Following the completion of this, it restarts. Upon restart it asks me to...
Hi, this is a common problem with ds, that happen if they have been sitting around for a while. they have a small watch battery inside that keeps the time and date running now since it has not been charged or used for so long then it looks like this battery has gone flat, you can try giving it a full charge and see if that makes and difference if not then your going to need to get the internal battery replaced, if you take it into most small phone shops they will be able to do the repair for you.
tell them the problem your having and then they will get this battery replaced for you.
try giving it a full charge first and let it go flat then charge it again if that still dont work after this then it will need a new system battery.
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 30, 2010 | Nintendo DS Console
I bought a used Nintendogs DS game for my daughter and would like to reset it. Anyone know how?
Pu the game in , turn your device on hold A, B, Y, X, L and R. Keep holding it down until it says "Would you like to erase?" also you may need to hold the stylus in your mouth when you press all these buttons start the game and then confirm you like to reset the game , Thanks
May 05, 2010 | Nintendogs: Dachshund & Friends for DS
Why is my ds lite keep resetting itself to factory settings?
maybe thereis something wrong with the machine.pls send it to ur after-saling center to let it run normal.
http://www.gameyeeeah.com/
Aug 10, 2009 | Nintendo Action Replay DS for DS and NDS...
A freezing nintendo lite!
The DS Card Slot may be loose. If so, try not to touch the game card while playing.
Or, there may be a piece of dust or lint in the card slot. If you can see the lint, pick it out with clean tweezers. If you cannot see it, ask a mechanic to open the Ds and pick the dust out.
Jun 10, 2008 | Nintendo DS Lite Console
Not working
go to "my nintendo" at nintendo.com and ask for a repair
Apr 04, 2008 | Nintendo DS Console
Can't get Past System Settings
this is a internal battery fault find a repairer or look on you tube as some people have done tuturial videos for diy
Mar 09, 2008 | Nintendo DS Lite Console
Language
If it altered the selected language in the game too, there should be a option in the game where you should be able to change the language. In most games at start up there is usually a menu screen where you can select:" new game, options, continue,(it sometimes might vary)" Language settings (if any at all) are usually found in "game options."
Exactly what game is this problem on? I'm assuming that since your daughter changed the language, that she knows how to go back to the DS configuration settings to select the language. If that is the area of information that you did need though, You can post another comment here asking that.
If what I've posted isn't helpful, a recommended place for DS and game support is found here:http://www.nintendo.com/consumer/index.jsp
Jan 13, 2008 | Nintendo DS Lite Console
WiFi query
    First DS (system you are transferring the ID from)
  1. Turn on any Nintendo WFC-compatible game and access the WFC Setup Utility. (Consult the game manual for the game you are playing for specific information.)
  2. Tap "Options."
  3. Tap "Transfer Nintendo WFC Configuration."
  4. Tap "Ok", then tap "Ok" again.
  5. Second DS (system you are transferring the ID to)
  6. Remove all games from the DS you wish to transfer the settings to, then turn the system on.
  7. On the DS's main menu, select "DS Download Play."
  8. Select "Nintendo WFC Configuration Transfer."
  9. Tap "Yes" when asked if you want to download the software. The word "Downloading..." will appear.
  10. First DS
  11. On the DS with Nintendo WFC configuration, tap "Ok" to confirm that you wish to transfer the configuration.
  12. Second DS (system you are transferring the ID to)
    • If there is an existing configuration on the new DS, tap "Ok" to confirm that you wish to overwrite the existing configuration.
    • Once the transfer begins, it will take about half a minute.
    Both DS Systems
  13. Once the configuration has been transferred, tap "Ok" to save the changes and shut each system off.
All of the Friend Codes you had given or received on the previous Nintendo DS will now work in the Nintendo DS system you transferred the ID to.
I just copied that from nintendo.com's customer service for you... it's better than how I could explain it.
Oct 22, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
168 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
