Question about Gateway GT5220 PC Desktop
When I turn the computer on it just beeps!
When I turn the computer on it beeps every four or five seconds. Sometimes the screen comes on, yet just a mess of colors and some times it is gray. It does not respond to the key board or mouse. I did make sure both where plugged in properly. I can not shut the computer down, it does not respond to Ctrl/Alt/Del, nor will it turn it off with the power button.
Any assistance will be appreciated.
Thanks,
Don
    Problem Solver:
  • 13 Answers
Press and HOLD the Power button for 5 seconds ...this will turn off computer ......her's a list of beep codes http://www.computerhope.com/beep.htm
These may help !
Try a different keyboard /mouse if you can /make sure NO pins are bent or missing on PS2 connection .....
When booting up computer hold the DEL key down this will take you into the BIOS.......Select LOAD DEFAULTS usually F10 ...you'll see it on bottom of screen .....Save when prompted and see if it boots......Good luck
Posted on Jun 03, 2008
Why won't my screen turn on despite the rest of the TV powering on?
Don't open up the TV. You may regret it. Unplug the set for 5 minutes....not just shut off....uplug the power plug from power source and replug after 5 minutes. It may need resetting.
Jul 02, 2016 | LG 42LE5400 42 in. LCD TV
Tip
How to fix a PS3 when it's frozen at startup
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Step1
The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
· Step 2
Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
· Step 3
Time to enter Safe Mode.
Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
· Step 4
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
· Step 5
jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a05/kb/9c/fix-ps3-it_s-frozen-startup-1.5-800X800.jpg'); }); Connect controller to PS3 screen.
You will then see this screen.
· Step 6
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
· Step 7
jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/a05/kb/9c/fix-ps3-it_s-frozen-startup-1.7-800X800.jpg'); }); Safe Mode options screen.
· Step 8
Select option number 3, (Restore File System). Then select yes to perform step.
· Step 9
You will then see this screen. "The hard disk's file system is corrupt and will be restored."
· Step 10
First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
on Apr 02, 2010 | Video Game Consoles & Games
My hp touchsmart310 PC will switch on but there is nothing on the screen ?
You can perform these steps even though the screen is blank.
  1. Turn off the computer, and then remove the power cord.
  2. With the power cord disconnected, press and hold the power button for five seconds.
  3. Reconnect the power cord, and then turn on the computer.
  4. Repeatedly press the F10 key about once every second for five seconds after turning the computer on.
  5. Wait five seconds.
  6. Press the F5 key. This restores the default settings of the BIOS.
  7. Press the Enter key. This accepts the changes.
  8. Press the F10 key. This opens the Save and Exit window.
  9. Press the Enter key. This saves the changes, exits the BIOS, and then the computer restarts.
  10. After the computer restarts, the screen should display the HP logo.
Hope it helps!
Aug 11, 2014 | HP Touch Smart Desktop Computer "brand...
When i turn my ps3 on it comes red and says a serious error has accurred.contact technical support for assistance
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Jan 05, 2012 | Sony Playstation 3 (PS3) Console
Corrupt hard disk
Connect controller to PS3 screen. You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen. You will then see this screen. Safe Mode options screen
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
My PC auto matically restart when turning it on
The beep you hear is your BIOS trying to alert you to an error in the POST (power on self test) routine. Without knowing the manufacturer of your motherboard one can't be certain what the beeps indicate...see this link for more info: http://www.5starsupport.com/info/beep_codes.htm
It's possible you have some kind of infestation, and it's possible there's something more systemic, but without knowing the make and model of your system I couldn't say.
Sometimes three beeps indicates a keyboard error...you could try another keyboard or unplug yours and see if it will boot up "normally" without it.
Otherwise, report back with some more info and we'll take it from there.
Mar 28, 2009 | Microsoft Windows XP Home Edition
Video quit...then everything
You computer did not pass the game requirements.
Mar 12, 2009 | EPoX EP-8VTAI Motherboard
Gateway GT5220 PC Desktop Logo
218 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
