Question about xheli 9053 Outdoor Volitation Metal Helicopter
My 9053 volitation wont lift ground, i checked top blade it's not loose from metal shaft, it also wants to spin heavy to the right in circles. I just it so I'm learning
  • 104 Answers
Had a similar model lasted 10 mins i broke this little plactic holder that seperates the blades i bent it the slightist bit and boom never flew again
Posted on Oct 16, 2010
  • kingtarzan Dec 11, 2010
    Look mate your obviously flying it in the wrong environmental conductions. Check the entire rotor system, some screw maybe loose prevention the blades to lift. Ensure there all tight and correctly in the the groove. From low revs, the are both sets of blades spinning...?
Volitation helicopter just spins to the left on ground and will not lift off seems top blades are spinning much faster then bottom
If one blade is spinning faster than another, then the helicopter won't lift off. The first thing to check is the gears driving the blade shafts. It could be that one of the gears is not set properly, or there is something caught near the shaft. Pet hair can often wrap around the shaft and cause drag. If the gears appear to be in the correct positions, and meshing with the pinions (small gears) on the motors, and there is nothing wrapped around the shaft, such as hair, I would slowly increase power and see if both motors start spinning at the same time. If they don't, there could be a problem with the motor, or the controller board. If this is the case, it may be repairable, but might be just as cheap to replace the whole helicopter.
Hope this helps!
Aug 29, 2013 | xheli 9053 Outdoor Volitation Metal...
Volitation 9053 lower blades not spinning
two screws that hold the whole assembley to the shaft wear down and have to be replaced or the won' t reach the shaft which cases the rotors to free spin. I just used two screws that were the same size but a tad longer. Seems to work so far.
Jul 09, 2012 | Toys
9053 will not take off
Lift is a function of the aerofoil. See that heptr blades are not bent or you or someone else have not tried to straighten the blades. They are at a specific angle to provide the required lift.
Apr 24, 2012 | xheli 9053 Outdoor Volitation Metal...
9053 bottom blades
Have the same problem with my S107 heli. I determined it's in the speed control hooked to the gyro control. This control feature helps keep heli
from turning in flight caused from tork. The lower blades are the ones
that speed up slow down to keep heli orientated. I'm replacing the control board.
Dec 16, 2011 | xheli 9053 Outdoor Volitation Metal...
Can someone tell me what might be wrong with my son's rc helicopter? It spins on the ground but does not lift off. It is a double horse volitation 9053.
it might be the controller that is broken. but it might be if he crashed it too much it could be broken. i had the same problem with my heli but i crashed it a couple times and now it does the same as yours hopefully im some help for u
Dec 09, 2011 | Toys
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
May 22, 2011 | xheli 9053 Outdoor Volitation Metal...
My 9053 lifts off fine goes left right and reverse. but it goes reverse also when i want to go forward . Tail rotor turns at what appears proper rpm. and it changes direction when i push stick from reverse...
I own this heli also. The problem is that the tail rotor does not apply enough push to tilt the heli forward. It is this forward pitch that moves the heli forward. Aside form buying a stronger tail motor, upgrading your battery etc, the only thing you can do id this:
Get a credit card, a pair of scissors and some tape. Cut a couple of strips from the credit card about 2 1/2 - 3 times wider thhan the tail rotor blades and the same length. Now tape the strips to the top of the tail rotor blades. Make sure you don't increase the length.
This will help a little by providing more air push when the tail rotor in engaged. Without some serious modding, this heli will never be great.
I have more fun flying my micro size syma helicopter in the garage then I have flying my volitation. If there is even the slightest breeze, the volitation will float in the direction of the breeze and will not fly against it.
Apr 03, 2011 | xheli 9053 Outdoor Volitation Metal...
Bottom blade set does not rotate
Check the connection on the control board. The square plug may have come loose.
Feb 05, 2011 | xheli 9053 Outdoor Volitation Metal...
Hi my helicopter is 9053 , my helicopter working but dont rise , meanwhile it s charging is full , please help me for how to rise many thanks
if the blades are turning and it wont rise check the top blade turn with you hand and hold the lower gear if it spins its loose the clue inside dont hold the turn blades.
solution: get a small drill bit not to big and a drill at the middle of the shaft by the black part make a hole down to the metal shaft and a littel bit into the shaft know get a small screw that woul fir the hold you just made and in to the shaft and it will hold and wala its fixed
Jun 09, 2010 | xheli 9053 Outdoor Volitation Metal...
Open Questions:
xheli 9053 Outdoor Volitation Metal Helicopter Logo
1,497 people viewed this question
Top xheli Toys Experts
MeAndMyBrain
Level 1 Expert
Tom Chichester
Rani wadia
Rani wadia
Are you a xheli Toy Expert? Answer questions, earn points and help others
