Question about Peg Perego John Deere Turf Tractor
How should I connect the wires to the motors? Our Peg Perego John Deere tractor lost its ability to go. I saw voltages on the motor wires when the wires were disconnected from the motors, but no voltage when connected. I replaced one of the motors and it started working. However, I may have mixed some of the motor connections when hooking it back up after replacing the motor. Now, when in 1st gear, the (new motor for the) right wheel spins fast and the left doesn't spin. When in 2nd gear, they both spin, but the right is fast and the left is slow. I may have wired it incorrectly, or I may need to replace the left motor as well. I believe the colors are red, white, black, and blue. How should they be connected to the motors for proper operation? If it's easier to describe without colors, what should the voltages be at the motors when in 1st and 2nd gear for proper operation? Thanks.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
White and black on one motor and red and blue on the other motor you can change which way the wheel spins by swapping the two wires around on the motor
Posted on Jun 06, 2012
  • 60 Answers
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Posted on Mar 11, 2009
  • 19 Answers
SOURCE: my sons peg perego john deere jeep only sets off
I would get the Peg Perego Gator Shifter Assembly from http://www.shopjandl.com/
Make sure the wires are secure on both motors in the back.
One time I had the same problem and I had loose wires on the motor, but I ended up replacing the switch assembly later because it would only work in 1st gear.
Hope this helps
Posted on Jun 09, 2009
  • 850 Answers
SOURCE: Peg Perego John Deere tractor 12volt will only
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Posted on Aug 17, 2009
  • 670 Answers
SOURCE: where do i find accessories for peg-perego john
Did you try here? http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
  • 670 Answers
SOURCE: We just replaced the battery and it worked fine
Use a meter to confirm whether the battery is still working. The meter should read around 12-13 VDC if the battery is good. The 12 Volt Peg Perego battery is made with 2 6 volt batteries connected in series. Maybe the connection broke when the battery fell out. Check the connection and also check with a meter if either battery is pumping out 6 volts.
Posted on Jan 03, 2010
John deere farm power tractor not moving, battery is fully charged and putting out 12 volts
check the voltage at the foot pedal, if you have 12 volts there, then check at the shifter, if you have 12 volts there then check at the motors, if you have 12 volts there then you have bad motors
Mar 15, 2013 | Peg Perego John Deere Farm Tractor and...
Can i put a 12 volt lawn tractor battery in the tractor
Wiring could be an issue when upgrading batteries. Also, if you manage to properly connect a larger voltage battery, you may (probably will) overheat and destroy the motors.
Sep 24, 2012 | Peg Perego John Deere Turf Tractor
Peg perego lawn tractor only one rear wheel turns at speed 2
sounds like a bad motor, swap the motors cables from left side to right and see if the problem follows if it doesn't then you need to replace the motor
Jul 14, 2012 | Peg Perego John Deere Turf Tractor
I want to test motors on pergo gator can i hook up reg 12 volt lawn battery to test that they spin or can i test charger
no don't hook it up to regualr 12 volt battery, first check the voltage of the peg perego battery and make sure that its putting out 12 volts, then you can use jumper wires and connect to the motors with the peg perego battery and verify that they work
Jun 25, 2011 | Peg Perego John Deere Gator HPX Ride on...
How should I connect the wires to the motors? Our Peg Perego John Deere tractor lost its ability to go. I saw voltages on the motors when disconnected from the motors, but no voltage when connected. I...
Hi, you might have fixed this already, but I usually email the repair department at help@mypegperegoparts.com if i need any help with my kids toys.
hope this helps
Oct 16, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Turf Tractor Logo
184 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
