Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Video 1 illumination wont shut off. - Sony FD Trinitron WEGA KV-32FS100 32" TV
    Top Expert:
  • Sony Master
  • 74,383 Answers
There is trouble in the video swithing Ic inside your Tv. Either it may got damaged or video swiching voltage may not come to it from system ic. If the video swiching Ic is damaged, it is easy to replace and get the set repaired. If the System Control Ic is damaged it will cost more and may need retune it after replacement and giving its remote service code for further adjustments. You just call a technician and consult him about the matter.
Posted on Oct 17, 2010
Why is it difficult to start?
Because the anti-theft system has a problem an won't let it start !You need to take it an have the DTC'S read or do a bypass . You can look on YouTube videos on GM Vats , passkey bypass !
Aug 29, 2015 | 1997 Buick LeSabre
2002 q45 radio
Its a hardware problem. should be solve in service centre.
Apr 02, 2013 | Infiniti 2002 Q45 Radio a1z112354 cassette...
I run my finger over the power button but it wont turn on.
You don't need to run your finger across it, with the red light illuminated, press and hold the power button for 3 seconds you should hear a beep then a blue/green light should illuminated. If you see no light ensue the MAIN power switch on the back is switched on.
Rylan
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
2005 gmc sierra. Manual shift 4wd. After using
When you are finished with your 4 wheel drive,put the transmission in neutral, disengage 4 wheel drive and shift to reverse then back up a couple feet before shifting to forward gear.
Jan 15, 2010 | 2005 GMC Sierra
Why does my TCS and ABS lights come on while driving? I can find no button to not use these options. I drive a 2001 Hyundai Sante Fe. Are they supposed to come on automatically?
no theres a problem with the abs, when abs doesnt work it turns on both those lights, you have to have computer scaned to get codes to diagnose the problem, it maybe just a wheel sensor. you cant turn it on or off, but you can still drive like that you just wont have abs trac-control when lights on computer shuts it down, so its like you shut it off, if you dont need it then dont fix it,wont affect running of engine .good luck.
Nov 07, 2009 | 2001 Hyundai Santa Fe
Monitor goes through a rainbow of colors when shut off; till power shut off.
Try your monitor on other desktop or laptop, if the problem persist - change the monitor or borrow one and try it on the same computer as it could be your video card. hope this helps...
May 25, 2009 | Dell Dimension 3100 PC Desktop
Stays illuminated wen shut off.
Sounds to me like the (+) wire that is supposed to be hooked to the dashboard light circuit is instead hooked to something that is on all the time, such as Battery (+).
Mar 02, 2009 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
Abs light wont go out
When u power up the vehicle ABS does a self test(light stays on a few seconds then cuts off) and if it see's a problem will shut off and illuminate the ABS lamp. It will also do a second test on iself when you reach a speed of around 12-15 mph,it will run the pump for a few seconds to check pressure and look at the speed sensors,if it see a problem here it will again shut down and illuminate the ABS light.
Now if the red brake lamp is on then it will shut down because it thinks you have a hydraulic concern and will not try and run ABS if this is the case.
If red brake lamp is on most likely if you have good brakes it is a problem with the float sensor in the master cylinder reservior,maybe its bad or just stuck,or just low on fluid.
Feb 12, 2009 | 1992 Ford F250
Hi..I have a problem with my wii controller. I can point with it but it wont let me be player 1 or wont move in the games..can you help me???
try resyncing your wii mote. take off your battery cover on the wiimote and you'll see a sync button push it! the lights should illuminate on the wiimote letting u know u are player 1. if this works and your still having trouble.... Put your wiisensor bar perfectly center on the top of your tv and check the calibration of the sensor bar in the wii settings menu on your wii
Jan 06, 2009 | Nintendo Wii Console
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
