Question about Andis 01690 Hair Trimmer
I've had two of these Oster A5's over the last 10 years. They work great when they work. But on ocassion, they will cut then quit. I have cleaned them, oiled them, adjusted them, checked the plastic shield is riding in the groove correctly, everything works perfect; they just wont cut. Then they will; then they quit again. Am baffled. This happens out of the blue. Dont know what causes it, or what fixes it.
  • 193 Answers
Have the blades been sharpened recently?
Posted on Nov 23, 2010
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
I have a brand new set of Oster A5 model #78005 clippers. We own two large dogs--we cliipped the first one and it worked beautifully--we were about half finished with the second one and all of a sudden...
I'm sorry if this sounds academic, but regardless of whether or not the problem lies with the clipper or the blade set itself, since it is brand new, return it to the seller.
Apr 09, 2011 | Oster Golden A5 2-Speed Universal Motor...
I have an A5 clipper, with three blades. I have had difficulty with this clipper, ever since I bought it. I have a schnauzer with very fine, soft hair, a bouvier, with very thick hair, and a Lakeland...
hi, on some ocassions when the clippers get hot the metal gear shaft moves meaning the movement of the clipper is limited, you can remove they gears in the gearbox when its hot and see if there is any side to side movement.
Nov 26, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 Clippers will not cut
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Aug 23, 2009 | Oster Golden A5 1-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
These kinds of clippers are fussy about oiling and dirt. It is essential that the blades be spotless and well oiled FREQUENTLY. Oil after every haircut always. Also, if there is not enough tension on the blades, the hair will slip between the blade and blade guard, getting caught and damaging the blades. Blades should be screwed on tight. Also, it may be time to replace the blade if nothing else helps. These blades do not last very long in my experience especially if not carefully cleaned and oiled.
Feb 28, 2009 | Oster Golden A5 1-Speed Universal Motor...
Andis 01690 Hair Trimmer Logo
83 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
